Changing tires without a jack or lift
Mr.Dee
MN
Lots
Assuming the user had independent control of the adaptive suspension, it's theoretically possible to remove a wheel and tire from the Cybertruck without the use of a jack or lift.
The stressed skin creates a much larger net section (inertia) than what is possible with a typical truck frame. This would result in less deflection from corner to corner, allowing the truck to lower the suspension in one corner, lifting that tire off the ground with much less deflection than a traditional body-on-frame. The distributed mass of the battery assures a similar loading on all four corners, making it possible to change all 4 wheels, one at time, without the use of any type of lifting mechanism.
At first glance it sounds like a simple party trick but, in reality, it could be a big game changer for the DIY or off-roader crowd.
alan auerbach
Retired prof.
My 1960s Citroen did that. Set the control to raise it full, put a strut under the side with the bad tire, lower it full. Both wheels on the strut-side stay off the ground. You'd then wrench the bolt. (Not bolts -- there was one per wheel.)
gphenix
Gary
Canyon, Texas
75th Anniversary Jeep Grand Cherokee, MERCEDES AMG SLC43
Ah, yes and with the on board air compressor a torque wrench with a limit to stop at the right torque.
Archer
Daniel
Orange County, California
Service and Repair
Assuming you're somewhere level enough, the ground is firm enough, etc.
But yes.
Practically speaking... terrain that is not level would not be an issue and may actually make it easier to change a tire in some situations.
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
The air bags will not lift an axle or wheel, it will only exert downward pressure.
