Charge schedule will not reach charge limit
dotat
AWD CyberTruck
Sales
Anyone else seeing this when they have their CT set to charge? I am getting this pop up on my iPhone basically every time this goes to charge.
Before anyone asks, yes my charging schedule will allow a full charge.
I charge at 48 amps / 11.4kwh on a hardwired Wall Connector. My schedule just sets the end time and my on peak price is 2pm-8pm.
I plug it in before going to bed, charging set to stop between 8-11am depending on the day. In this case, it only had about 50 miles to add to get to my 80% charge limit.
Funny thing is, it actually completes the charging a little bit ahead of schedule too.
This is my first Tesla & EV. I didn't get this alert the first month or more of having the CT either.
Tesla Cybertruck Charge schedule will not reach charge limit will not charg
igs
CT, MX, MY
Gaximus
Mead, CO
Software Developer
Never seen that before, Also you should name your CT so you don't get notifications with a VIN number.
I'm thinking a good name would be "Cheater, Cheater.." ?
RickJ19Zeta8
Wisconsin
Yes, I'm getting the same thing every morning. Same deal, scheduled charge to finish at 6am on a 48amp hardwired wall connector. Adding about 50 miles also daily.
Truck is charging fine, no issues with the charger or house voltage. And charger works fine with our Model 3, set to the same charge schedule.
Pretty sure its a bug and will be fixed in the next software update.
sharpgator
Scott
Birmingham, AL
26 AWD CT, M3
I have the same issue. It started the night after a software update so I feel like it will eventually get corrected.
'23 MYLR, FS Cyberbeast 280xx
I can confirm same. I thought my CT was "learning" my charger. First day, it charged to 78%, 2nd day, 79% and it's been getting to 80% every day since.
Also, every day I work, I start with 80% and end the day with 52%... I was going to charge every other day but we live in an area crowded with a lot of really big, damaged trees and power lines. With my Powershare, when it gets installed, I want to make sure I have the power... ultimate power.
AlmostHuman
Earth
Model X, Cybertruck
Human
I have not seen that but I never set the “End Charging by” on my schedules. I just do the math and tell it when to start.
If you are plugging it in after 8PM, then remove all charging schedules, they aren't needed.
If nothing else, just try it.
How many miles do you drive daily?
dotat
dotat
AWD CyberTruck
Sales
My miles vary a fair amount, but most weekdays it's only 20-50 usually.
I do the charging schedule "end at" time as I like to maximize my solar in the morning if I don't have anywhere to be early. It's easier than changing it daily to match how much I need to fill up.
Getting into the winter now, I tend to make more with solar than I need, so I'll adjust my CT charging again when our peak times change so I will be charging 9am-5pm most of the time.
It does work fine, so no big deal, just making sure I wasn't the only one seeing the error.
