Cybertruck as a tow vehicle
AlexD
AlexD
Alex
Virginia USA
Lexus 460LS, Model 3 dm, Mustang Boss 302, F150,
retired Building Contractor
When I started my trip the tank was pretty low and I put in 27.2 gal gas
On the trip I never put in more than 21 gal - being conservative & not risk running out. Notwithstanding, GasHog always got over 300 miles before I had to refill. 140 miles range is simply NBGAA! Remember we are doing the comparison with a 2003 real piece of shit! Goodness there are any number of better tow vehicles than ol' GasHog!
AlexD
AlexD
Alex
Virginia USA
That's a 32% increase in fuel consumption to go from 18mpg to 13.5. I don't know where you got the 18% from.
308miles driven and
I did the math. You consumed 0.055 gallons per mile (18mpg). Then you put the trailer on and consumed 0.074 gallons per mile (13.6). That's an increase of 32%.
I don't know what your math was about, because it makes no sense. You consume gallons, not mpgs.
Drive 308 miles and use 17.672 gals gas = 17.4287 MPG say 17.43
Which part of this simple calculation is giving you problems???
Okay, if switch to 17mpg as the baseline, you still used 25% more gas to go the same distance at 13.6mpg.
AlexD
AlexD
Alex
Virginia USA
The actual real world figures show that there is only about a 15% increase in fuel consumption on my old 5.4L V8 2003 F150.
I put the address into my Model 3 and let it plan my route. Warrenton (VA) to Bloomington Indiana is about 630 miles according to the Tesla.
Recharge at La Vale MD - 30 minutes
recharge at Cambridge Ohio - 30 minutes
Recharge Dayton Ohio 25 minutes
Arrive Bloomington with 15% charge left - and there is no Supercharger anywhere near so I would have had to recharge at Indianapolis which is about 40 miles from Bloomington. Now this is my Model 3 not towing. So its 4 charging stops just to reach my destination (with plenty range left to do my return start off)
Towing I am probably going to average 80 miles range to fit in with the supercharger network and this would mean 630/80 = 8 recharging stops on the return trip!
That's a total of 12 recharging stops vs 4 refueling stops in the GasHog.
Afraid this doesn't make good reading and I'm the biggest EV fan but not blind to reality.
You know, you can charge at any J-station or Tesla Destination station, too, while you take a meal or sleep for the night. You don't just have to charge at Superchargers.
Dawgfan
Peter
Vancouver
JL Jeep, Chevy S10, Infiniti Q60
I really don’t think the range when towing will be that great but it works for me because in all my 35 years driving a truck I haven’t towed anything over 50 miles. Diesel trucks still have their place and it won’t work for everyone.
AlexD
AlexD
Alex
Virginia USA
Crissa, the road from Cincinnati to Indianapolis is flat level freeway for ever. I drove one way not towing and the other way towing at very similar speeds. Not towing I got a fuel consumption of 16.82 mpg. Towing I got 14.43 mpg. Same road, similar speeds and similar conditions. That is a difference of 2.39 mpg - heavier whilst towing.
2.39 as a % of 16.82 is 14.209274% different. (to 6 decimal places!!) This is not rocket science. I used less than 15% more fuel when towing in the old GasHog.
Please note the second part of this trip is pretty mountainous so obviously the closer to home the worse the fuel consumption would be whether towing or not towing. That's why I believe using the section in and out of Indianapolis is going to give the correct comparative figures. But even if you use average consumption loaded vs unloaded doesn't make that terribly much of a difference. I did state that I also drove this section differently because some parts were driven at night.
Truly, use the into and out of Indianapolis statistics for the most accurate comparison. I am not trying to fudge the figures. This is my real life reality, very accurately documented. I have no vested interests. If you don't like the figures that's tough shit but its the reality.
You got 14.43 mpg in a section when you towed only part of the way. So why would you select that sample and not the other part?
AlexD
AlexD
Alex
Virginia USA
I left Warrenton at 03.30 am on Friday 16th April. Arrived in Bloomington Indiana at 2.30 pm same day. Did the paperwork, hooked up the boat and headed back home. Slept at some Best Western and was back home in Warrenton the next day at 3pm. About 1300 mile round trip. This is all like 2 weeks ago - Not a pleasure to be sure!
AlexD
AlexD
Alex
Virginia USA
Look carefully at my log published earlier.
At odometer reading 104028 was where I refueled at Bloomington (40 miles west of Indianapolis) where I hitched up the boat. On this leg I had a fuel consumption of 16.83 mpg - not towing.
The next fill up at 104334 was the first refuel while towing and I used 14.43 mpg.
The route is identical but in the opposite directions and the road is straight and flat.
I was not hanging about and was driving at 75 to 80 mph in both directions so its a fair comparison. It amazes me that the old GasHog didn't use dramatically more fuel when towing. These are the facts, plain and simple. I have the log book and petrol slips to prove it and why would I bullshit anyway? Remember you are dealing with an BEV fanatic - not an ICE fan by any stretch of the imagination! I absolutely love my Tesla and will never change it but sadly realize I will have to also keep an ICE vehicle to do my towing because long haul towing is the EV's Achilles heel.
The only - and I mean only - reason a truck would have a higher towing 'penalty' is because it was more aerodynically small than another truck.
Because when you're towing, what you're doing is raising the cross-section and lowering the aerodynamic efficiency. A trailer's aerodynamics barely* change when you swap the towing vehicle.
So really, looking at it as 'this truck only does 18% towing penalty' is the wrong way to look at it. It probably means that truck is wasting energy all the time that you don't notice.
* It's possible for the wind-shadow of a truck to work particularly well with a specifically designed trailer, or to have more of a wedge that creates more of a shadow for trailers to fit into at a specific speed. See also the profile of the Shinkansen vs Amtrak engines. But few pickup trucks are going to have that sort of profile. Well, except maybe a Cybertruck...
android04
Dario
Crete, NE
2023 Tesla Model Y LR AWD w/Boost, 2018 Tesla Model 3 LR RWD
The bass boat didn't affect your aerodynamics as much as a camper or enclosed trailer would because it doesn't have a lot of frontal area and is smaller that the pickup. If you were to haul a camper or enclosed trailer with the same pickup, your fuel consumption would probably be close to double (also depends on speed). The Model 3 is smaller than your truck and will expose more of the trailer to the wind. Cybertruck will be bigger than a Model 3, so it will not be directly compatible.
By the way, I've towed a small utility trailer with a lawn tractor 140 miles at about 65 MPH multiple times and my energy consumption was around 400-420 Wh/mi. Combined trailer and cargo weight of 1200 lbs, but consumption isn't much different with an empty trailer. On my 2018 Model 3 LR RWD with a range of 308 when brand new, that trip non-stop takes my battery from 100% to 5%. With Cybertruck, I expect the range hit to be less.
MEDICALJMP
Jeff
Omaha, NE
Nurse
One thing you may be forgetting is that supercharger/charging stations are not static. There will be more charging stations added in the next 5, 10, plus years. More gas stations are adding EV charges so driving out of the way today won’t necessarily mean you have to when CT is available to you.
Yes, it can be a pain taking the road less traveled right now. I’ve bitched about that myself however, the times they are a changing.
Firetruck41
Ben
SW Washington
Boats are amongst the most forgiving to tow, due to aerodynamics.
Towing a travel trailer or enclosed cargo trailer will exact a significant penalty in efficiency/range. I'm surprised this is a surprise to anyone that tows? It is not uncommon for me to lose 40-50% mpg in an ICE, towing a travel trailer. I would expect similar in an EV.
This will be a problem for some people's towing needs. Others are towing a construction trailer around town, or travel trailers for short weekend trips and will be fine. It all depends on your needs and willingness to wait for a charge.
