- Oct 3, 2020
- Western Washington, USA
In my Model 3 Performance, I get there a lot sooner, including Supercharger stops, if I go 120 mph. Bjiorn had the same findings on the Autobahn in Germany. The faster you go, the sooner you will arrive. The reason for this is that charge speeds are in the hundreds of miles per hour, often exceeding 1000 miles per hour initially.The numbers that I use is the you drop about 10% range for every 5 mph increase over 60 mph.
This can be easily seen on the Energy graphs, drive one speed for about 10 minutes and then another speed.
BUT, when you are NOT in an area where range is a problem 70-75 is the speed at which you go the furthest, the fastest, including Supercharger stops. But ALWAYS make sure that you roll into a Supercharger near empty. If you charge from 20$ to 80% it will take about 15 minutes longer than 5% to 65%.
Of course, that assumes I don't get delayed by those guys with those colorful lightbars on top.
