Door Remote Open
Brandon708
Brandon
Downers Grove, IL
oneupsigns.com
Cybertruck, GMC Seirra, Model X, E-Transit, F550
Sign maker
This is a great new feature I have been looking forward to. It's a great start and I hope that the next update will allow the door to pop open automatically when you walk up to it like the Model X does.
Tesla Cybertruck Door Remote Open IMG_4249
Gavinbee
Toronto
Cybertruck Beast, 2020 MYP, 2023 MXP
Actually, interestingly enough, if you press the button to open the door, wait 30 seconds, the door attempts to close itself, albeit not all the way... so close! ;)
Gavinbee
Toronto
Wes from Tesla said they will not add the auto door pop to the CT because the door cannot close itself.
Curious, what does it matter if the door cannot close itself? Auto door pop would be beneficial as it saves a step of pressing the physical button and then opening the door. If you are presented with the door already open, it makes it pretty effortless.
Brandon708
Brandon708
Brandon
Downers Grove, IL
oneupsigns.com
Sign maker
You're right. IT does try to close itself. But doens't pull it shut like the X.
Still, I would like this walk-up feature as an option you can choose to do if you want it.
SCTesla
22 Model S, 24 CT
Because the door opens when you approach with Bluetooth and there are a lot of instances when the door wasn't intended to open. With the MX, it will just close when you leave BT range, the door will still be cracked with the CT.
It's not my perspective, that's the perspective from Tesla. He said he could see delivering door pop in the app like the 3/Y, but not automatically like the MX.
Fvansan
Frank
Naples, Maine
Tacoma and pre-ordered a cybertruck dual motor
Retired Psychiatric Social Worker
I find my door opening not always functioning when button is pressed. May have to push several times to open door.
SCTesla
22 Model S, 24 CT
Either a faulty button or an issue with your phone putting the Tesla app to sleep.
It's not really trying to close, it's retracting the plunger that holds it open.
CT007
FS Cybertruck, X plaid, YP, S LR, 3P
Exactly. This happens even if you open it manually, the plunger goes back in after some time.
mahdir35
RaĂşl
Foundation Series AWD
Project Manager
Because if you don’t open the door then the door is left open…unsecured
mahdir35
RaĂşl
Project Manager
Put in a service request
Gavinbee
Toronto
Same thing would happen with model X opening trunk with UWB enabled, you need to close it manually.
Long story short, you could disable the auto open door if you don't need it.
