Dual motor power split drive train
@abebarker
Please tell how much potential regen energy is available at 10, 40 and 70mph.
And then how much of that a standard Tesla can recover in comparison to the split device.
Note that rolling to a stop (or using hypermiling driving techniques) is going to trump regen every time, because it avoids charging and then discharging. Just slow down earlier when approaching an intersection, no split device required.
Which btw isn't your design at all from what I can tell, can you provide proof otherwise?
As has been pointed out multiple times more torque is useless if existing vehicles are already operating on the tyre traction limit. The only reason to add it would be to reduce motor size and still be able to move heavy loads, albeit more slowly.
Now if you want to discuss how optimizing the motor RPM to the vehicle speed can improve efficiency, that is something else, but keep in mid that Tesla doesn't just use induction motors either, so you numbers will vary accordingly.
This is a typical efficiency heat map for a Tesla Motor:
Tesla Cybertruck Dual motor power split drive train {filename}
(1rad/s = 9.54 rpm Note: blue is 80%, so maximum gain possible at those rpm is 18%)
On that please highlight where exactly you expect to achieve any meaningful efficiency improvements from a split device, given that most of the time a vehicle does not need to accelerate hard, and therefore has a low torque requirement.
GnarlyDudeLive
Darin
Chicago
Model Y Dual and Cyberbeast
Is that like the road version of the cut and paste function on my PC keyboard? ?
Nope, that is what happens to your body when said 100k semi actually runs over you in the process of cutting you off. LOL.
Damn typo's
You are confusing performance with efficiency.
If it were not for falitious logic, some people would seemingly have no logic at all.
You are just confused.
As usual when someone says “you aren’t smart enough to understand it”.
What they really mean is they don’t understand it enough to explain it.
