Engineers hitting 1.2MW on Semi Megacharger
CyberTrk
Cyberspace
サイバートラック
Gaximus
Mead, CO
Software Developer
Gyatt dang thats nuts. Wonder how long that would take to finish off a CT
I calculated (I as in GeminI) these results by taking the Cybertruck’s 123 kWh battery capacity and applying a 4.0\times multiplier to its real-world 325 kW peak charging curve to reach your theoretical 1300kW limit. I then integrated the power over the state-of-charge (SoC) to determine the time required for each segment, assuming the charging speed still drops as the battery fills to protect the cells.
• 10% to 60%: 5.1 minutes
• 20% to 80%: 9.2 minutes
• 0% to 100%: 23.8 minutes
Tesla Cybertruck Engineers hitting 1.2MW on Semi Megacharger 1767247237134-2z
Too bad the CT has 4680. The batteries would crap out.
My dude, there have been a handful of CTs charge at 500kW. Why are people on this kick that the 4680s are bad? They are still one of the most advanced batteries on the planet right now.
So can anyone please explain what the barriers are to a better charge curve on the CT?
As fantastic as my truck is, the supercharging performance is honestly less impressive than I expected.
Our 2024 model x honestly does better in terms of real world useable charge times.
I do understand that battery is smaller but the max charging speed is also less.
Both are obviously a huge step up from what our legacy p90D plus did but I was expecting a little more from the CT.
500kW is not 1.2 mW wonderful try however my dude.
The barrier is the cell.
Heat, mostly. You've probably noticed the AC working overtime while Supercharging.
Of course, you can charge despite the heat if you don't mind getting only 200 charge cycles instead of 2000. The curve protects cell longevity.
So why doesn’t it charge faster in say cold snowy climates?
IKR! In the cold, the AC can be more efficient, but you're still limited by thermodynamics and the ability to transfer heat from the cell to the coolant. Charging is actually slower when the cell is cold; there's a fairly narrow temperature range for optimal charge speed.
Theoretically, smaller cells are better at heat shedding due to the higher ratio of surface area to mass. The tabless design compensates for this somewhat by distributing the heat more evenly across the surface.
I'm not understanding your reply here. The Cybertruck's charge curve is not yet matured, and there are very few stations that can output the current top end at 500kW.
Cyberskunk
Patrick
Minnesoata
2025 AWD CT, 2020 3 LR AWD
Tech
If it is too cold energy goes into preconditioning and too hot makes it harder to dissipate heat generated during high-power charging.
60-70F air temps are where it fast charges the most efficiently.
