ldjessee
- Lloyd
- Apr 22, 2020
- Indiana, USA
- Nissan Leaf, MYLR, Kaw 1700 Vaquero
- Business Intelligence Manager & Analyst
I think rear wheel steering will help also eliminate the need to jack-knife as much (atleast it seems like rear wheel steering seemed to help with normal trailers)?Next problem is the obstruction caused by the CTs sail pillars. Those will cause problems when turning sharply and virtually eliminate the ability to jackknife when backing a trailer, which is absolutely essential when negotiating tight RV campground sites. BUT... the CyberTruck's independent air suspension system and the Reese Goosebox's air dampener can mitigate a LOT of the problems with the sail pillars.
If the CyberTruck's computer was programmed in "5th wheel mode" to dip the suspension on the side inside of turns, the sail pillar could dip out of the way on normal turns.
When backing the trailer, the CyberTruck could adopt an extreme Cheetah Stance that would serve to flatten out the problematic angle of the sail pillars. Granted, this would be at the expense of the departure angle of the travel trailer you're backing, and dragging the bumper off a travel trailer isn't a rare accident. You'd have to be really careful in these circumstances. An adjustable air suspension on your RV may be the best bet ($$$ ?)
Back in the good old days when we thought Tesla would provide an air connection in the bed of the CyberTruck tapping off the suspension compressor, I thought an extra airbag on the Reese Goosebox could also raise the overhang of the trailer in tight spots. But alas, the air-chuck didn't survive the design process. ??
Not only dip to the side, but left the back and dip the front as well, so the bed is higher and the sail panel tops are closer to being parallel with the ground (compared to how they normally are).
Just some thought from someone who has never driven a fifth wheel.
