Factory forgot to connect two Ring Terminals?
TCybertruck
While installing some Lights with the Frunk Tube removed, I’ve founded these two Ring terminals unhooked on the driver side that I’ve never messed with. Does anyone know where they’re supposed to be connected to?
Tesla Cybertruck Factory forgot to connect two Ring Terminals? IMG_8333
Tesla Cybertruck Factory forgot to connect two Ring Terminals? IMG_8334
dpoll995
I’m pretty sure that’s for emergency power, if the low voltage battery dies. You can connect a jump box to those terminals so that you can pop the frunk to get to the low voltage battery. Should also let you open the doors too. Check the manual under mid voltage battery. It shows you how to get to those terminals from the fender well.
TCybertruck
That makes perfect sense. Thank you
koolio
Greater Boston, MA
They just dangle there? Not separated from each other or isolated in any way?
