firsttruck
mx
Guías de rescate de emergencia para personal de primeros auxilios
Hmm, no mention of airbags in Tesla Semi.
Recommend cool battery with water but at same time do not submerge vehicle.
I would have thought submerge vehicle would be best way to cool the sealed battery.
Is it OK to submerge just bottom part ( a water height to cover battery) of vehicle?
Cybertruck-Rescue-Sheet.pdf
https://digitalassets.tesla.com/tesla-contents/image/upload/Cybertruck-Rescue-Sheet.pdf
Semi Emergency Response Rescue Sheet - 2022_SEMI_Emergency_Response_Rescue_Sheet_en.pdf
https://www.tesla.com/sites/default/files/downloads/2022_SEMI_Emergency_Response_Rescue_Sheet_en.pdf
Lithium is highly reactive with water.
For fun, cut open a Lithium-based AA battery and toss it in a bucket of water. Run.
Would this be weird to give to our local fire stations? Or do they already have this in their database.
They usually stay on top of these things, but I'm sure they'd appreciate someone concerned with fire safety.
I highly recommend bringing them a copy and asking anyone if they want to take a ride (or drive if you are generous). At least you will get to see if your local FD passes the vibe check.
firsttruck
mx
Yes, pure lithium or even lithium metal are highly violently reactive with water.
Lithium-ion battery is reactive but to lesser degree.
Pure lithium or even lithium metal are not exactly same as what is in most EV lithium-ion batteries.
Lithium-ion cell contain small amount of lithium and in case of a fire they can be doused with water.
Lithium-metal batteries on the other hand require a Class D fire extinguisher and you should use as little water as possible and mainly to keep the surrounding area from catching fire.
Most EV lithium-ion batteries are not pure lithium or even lithium metal. Only a very small amount of material in battery is lithium-ion. Elon said in EV battery, (content NOT price wise), lithium was like salt on salad .
Many Lithium-ion batteries also contain highly flammable electrolytes material (liquid or semi-liquid organic solvent) and other materials.
Flammability of Li-Ion Battery Electrolytes: Flash Point and Self-Extinguishing Time Measurements
2015 Jan
IOPscience
https://iopscience.iop.org/article/10.1149/2.0121502jes
Maybe the ultra high temperate burning & thermal runaway of large battery pack might be more important than how a few cells reacts with water.
If firefighters as pouring 10,000 gallons of water from large diameter high-pressure hoses in all possible directions on the battery, how is that significantly different than submergence in 2-foot of water in a tank (a lot less than 10,000 gallons)
Tesla Myth Busters (Lithium = Salt on Salad)?
Let play a game of Mythbusters with Elon Musk and the famous Lithium is just the salt on the salad comment.
Aug 15, 2020
EV Stock Channel - Tesla Documentary Series
Tesla Cybertruck First Responders Emergency Rescue Guides for Cybertruck & Tesla Semi 1724288502192-l
Recent Advances in Non-Flammable Electrolytes for Safer Lithium-Ion Batteries
February 2019
https://www.researchgate.net/public..._Electrolytes_for_Safer_Lithium-Ion_Batteries
Designing safer lithium-based batteries with nonflammable electrolytes: A review
eScience Volume 1, Issue 2, December 2021, Pages 163-177
eScience Review
https://www.sciencedirect.com/science/article/pii/S2667141721000501
Ljhughes8
Lajuan
Santa Rosa , Ca
Tesla model and cybertruck orded
Stay at home dad
Good to have .
DfibRL8R
J
My Mountain, Virginia
'13 S (sold), '18 3 (totaled) , '20 Y, '24 CT
The department I work with uses an app called Electric Vehicle Rescue
https://autorescueapp.com/
It has Emergency Response Guides for most EV's, the Cybertruck and Semi aren't on there yet but I suspect will get uploaded soon. I messaged them with the heads up on the new guides.
CarMan ElecTruck
Other Earth
LeftFoot RightFoot
If ‘First Responders’ are involved (as the title of the thread suggests) it may be best to keep a copy in your phone.. which will be pre-occupied with broadcasting live on the Twits and BookFaces…
I believe that flowing water would be significantly better than being submerged in what would become a localized pot of boiling water.
Getting the heat away with the water flow is the goal.
DfibRL8R
J
They are now on the app.
