Front Bumper Light bar by Tlyard
Last I heard there was some sort of speaker hiss issue with these maybe? Has that problem been solved? Anyone know?
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
Check out this new front bumper by Tlyard! It was super easy to install and super bright!
https://bit.ly/42nhZXr 30% off with this link!
Hi! Is this a bumper or light bar review? Post says bumper, video shows light bar. Is there also a bumper offered that I missed?
Thanks!
NVM, I got it! It's a light bar that integrates with the front facia; not a new bumper.
Oscar
Charlie
Katonah, NY
CyberTruck
You are talking about the light bar, not the Front bumper, right? I ordered a front bumper and tried to install it over last week. Everything went well, but got stuck when I tried to move the front camera forward. I just couldn’t get the camera out from the tinny opening. The camera could get damaged if I pull it out with too much force. Any clue?
Tesla Cybertruck Front Bumper Light bar by Tlyard IMG_8328
MrHayabusa
Todd
Bedford, MA
Tesla CyberTruck; Tesla Model 3
Software Engineer
Ok, I installed the same product (from a different manufacturer - but it is exactly the same light bar, obviously they all get them from the same place), and a couple of thoughts/questions:
I will say, I do like the light .. I have always liked adding extra light to vehicles - I am currently installing a sequential directional light to the back under the tailgate, and I have an UP off-road light on backorder...
First, an observation -I did not realize fully that the light sticks out significantly further than the original piece of plastic - which is fine, but it means that I cannot fit my fingers through to hit the frunk open button ... kinda annoying really. I do have the "auto open" function enabled, but that does take a few seconds
Questions: does adding a light bar like this void any warranty? Kinda late now for me, but thought I would ask
I am curious how you were able to just have the new light on without the headlights? what setting was that? I run in "auto" mode all of the time - and it seems like it turns the light bar on when the headlights are on (but strangely when I exit the vehicle and close the door, the headlights are still on until I walk far enough away, but the new light turns off nearly immediately? There is enough time for me to go out and see it go off ... just, strange? I am not sure what is telling it to turn off? But when I drive up to a reflective building I can see the light is on, even in the "auto" setting, so I don't have to set it to "on" always. Any help with this is appreciated! @Rick Zoerb
Seekmastery
St. Charles, Mo
2024 Cyberbeast
How do you install this if you have the power running boards installed? They both plug into the same area under the dash. The CAN connector.
Rick Zoerb
Rick Zoerb
Rick
North Carolina Us
2024 cyberbeast foundation
Hey. I’m sure they will work in line with everything else. I say that because I hooked the front light up in line with my C9 display. It worked perfectly, so shouldn’t be an issue. I will be doing a review install video of the power running board in approximately one week so I can give you better feedback after that if you would like. Hope this helps.
Rick Zoerb
Rick Zoerb
Rick
North Carolina Us
I’m not quite sure we have the same light because I can easily use my funk opener still. I do agree that most of all of this stuff is the same stuff through different websites, but like I said, I don’t have an issue with mine. Give me a couple days to get back to my vehicle And see what setting I have set for my lights as well. Hope this helps.
MrHayabusa
Todd
Bedford, MA
Software Engineer
Rick Zoerb
Rick Zoerb
Rick
North Carolina Us
Hmm ... I purchased mine through CTMods:
https://www.ctmods.com/products/tesla-cybertruck-led-light-bar-cybertruck-bumper-light-bar-mounting-kit-ctmods®
I wonder.. could I have installed the light bar itself upside down? :( I thought I had it correctly, but maybe the button is supposed to be on the bottom vs. on the top?
it’s definitely the top.
Tesla Cybertruck Front Bumper Light bar by Tlyard IMG_8468
MrHayabusa
Todd
Bedford, MA
Software Engineer
Gotta be honest - that looks like a very tight fit to me!!
I took 2 pics as well, open and closed. I can fit my keycard through to press the button, but my fingers just won't fit. Not sure if my lid goes down just slightly more than yours? My light is installed properly and is snapped in well (and looks extremely similar to yours!).
Still curious about warranty and turning on/off when you get a chance, thanks!
Seekmastery
St. Charles, Mo
2024 Cyberbeast
I got mine through Tesstudio. Both the power running boards and the grill light. I get a error on my frunk switch for the power running boards. They are telling me these two items are not meant to be daisy chained on their CAN connectors. The light works, but the running boards pop that error up. I did unplug the connection on the control box, and re plugged it back in when i had the frunk apart and got it to work. But it only worked until the truck shut off and didn't work again when I came back.
Tesla Cybertruck Front Bumper Light bar by Tlyard JPEG_20250323_123927_
