AverageJoe
Olive Hill, KY
2024 CT AWD, 2022 MYP, 2016 MX 90D
Retired Military, House Husband
TLDR: Thank you for the advice and trouble shooting steps shared here.
I was on a late night 7 hrs round-trip marketplace buy when my truck dropped the cameras and emergency braking ability in the middle of a fsd turn through a busy intersection.
I remember glancing over a bug about the new update. I couldn't bring up the post but willed myself to remember how it was fixed. Forcefully plucking the steps for resetting the ADAS and how to get to service mode to accomplish it from the farthest reaches of my brain on the spot. Saving the 3 hrs return portion when I needed FSD the most.
UPDATE:
How I did it-
Went to software tab on cybertruck screen.
Press and hold cybertruck logo until service mode prompt for password appears.
put in password (service)
Unlocked the gateway with right turn signal press and hold while holding the brake.
Then find driver assistance, cameras, and finally reset DAS.
Edit wrong video was attached
Similar process on model 3/Y
CT_AZ_4x4
Jay
Scottsdale, AZ
AWD CT
Self employed
What was the fix?
what was the solution?
AverageJoe
AverageJoe
Olive Hill, KY
How I did it-
Then find driver assistance on the list on left and select it.
Select cameras
Select reset DAS
Unlock the gateway with right turn signal press and hold while holding the brake.
Edit wrong video was attached and steps in wrong order
How I did it-
Thank you. That’s very helpful. Will stash that Info for a rainy day.
stymeist
Joseph
Granite Bay, CA
Model Y and Cybertruck Dual Motor
I too am grateful for this forum. I had the exact same problem. Made an appointment to get it fixed and it was going to take weeks to get in. This solution was a life saver as I use FSD religiously.
koolio
Greater Boston, MA
Just watched the video and I see the correct step is to:
1. Tap on reset das
2. The do the turn signal + brake command to trigger the reset.
the way it was written made it sound like one had to do the turn signal + brake to get the ‘reset dash’ button to appear.
AverageJoe
AverageJoe
Olive Hill, KY
1. Tap on reset das
Thank you. I will edit the post.
You can see why I was so surprised I pulled what I did from my memory.
EXPTREVER
Trever
Folsom, CA
Cybertruck, S, 3, X, Y
I had to reset the DAS many times in my model 3 because the cabin camera wasn't working reliably. Eventually went to epc.tesla.com and purchased a new cabin camera for less than $200. Put it in myself (very easy, many youtube videos on it). Never had to reset DAS again :)
Hopefully I don't get this software glitch with my CT, but now I know the fix. Thank you!
HMGT3
Muscat, Oman.
Hi. My ADAS has failed multiple times now. Each time, a reset fixed it temporarily, but the issue keeps coming back.
Is there any way to determine which camera or sensor is causing the fault? Are there specific logs, alerts, or Service Mode screens I should be checking when the failure occurs?
For those who have had similar issues, was it a particular camera, wiring issue, calibration problem, or something else?
