Installing a 12 volt radar detector -- use 12 - 15 volt circuit behind the rear view mirror compartment.
CTMike
Cocoa Beach
Cybertruck FS
In case you are interested, you can install a 12 volt radar detector up next to your rear view mirror. There is a 12 - 15 volt circuit behind the rear view mirror compartment. It’s not necessarily easy to tap into the circuit, but it can be done if you have some mechanical skills.
Bkb13
Austin
raptor
Entrepreneur
I had trouble trying to figure out a place where I could place the radar detector up top. The Sunvisor six make it difficult to situate a radar detector. I guess the best alternative is to replace the rear view mirror. But I like a more stealthy install.
Instead, I made a mount that would hide the radar detector behind the screen. It attaches to the vent and you could slide it left to right.
https://www.cybertruckownersclub.com/forum/threads/radar-detector-movable-dash-mount-mod.19761/
XQUIZIT
Lenny
New Jersey
Cybertruck, Tesla Model X, Porsche Panamera Turbo
Self employed
HelfFL
Cybertruck, Porsche Taycan Turbo, Tesla Model 3
I followed the instructions and parts described in @edc's video. Tapped into the white connector as @edc recommended. I did not test the voltage, but Escort Redline 360c works with this connection point. I did have to set the detector to auto-off after 1 hour (lowest setting) otherwise it does not go off if sentry mode is turned on. Then it will turn on again automatically when I return to vehicle. I'm ok with it being hidden behind the visor.
Tesla Cybertruck Installing a 12 volt radar detector -- use 12 - 15 volt circuit behind the rear view mirror compartment. IMG_3829
TeslaKen
Ken
Overland Park
www.halocybertruck.com
Currently Occupied
Does anyone know if there are mounting brackets for the Escort to go where the rear view mirror is? I know a couple of other 3D printed brackets exist for other brand detectors but wondering about the Escort. TIA.
marsh1
Houston TX
2024 CyberBeast
Business owner
Using this for my Escort. I did pop the camera cover and tapping into power would be easy but I like that I can take it off and put in center console and no wires hang out.
https://www.etsy.com/listing/1742233905/cybertruck-escort-radar-detector-rear?ref=yr_purchases
This cable
https://www.amazon.com/dp/B0CPY64DQH?ref=ppx_yo2ov_dt_b_product_details&th=1
Tesla Cybertruck Installing a 12 volt radar detector -- use 12 - 15 volt circuit behind the rear view mirror compartment. IMG_3019
TeslaKen
Ken
Overland Park
Currently Occupied
shuakin
Josh
Metrowest Boston
Model 3, Model Y AWD, Cybertruck AWD
I saw in the headliner there is a 12v internal radar. You could use a 12V Dc - DC converter from that plug to USB-C, then barrel the usb-c to your RJ-11.
Ward L
Ward
Camarillo, CA
Model Y, FS CT AWD
I ordered the Tesla tire air compressor kit with my referral points thinking I could use it on my two Teslas. Turns out it has a standard 12v cigarette lighter adaptor for power. HUH? If I paid for it I would send it back. There may be a workaround, but as soon as I saw the cigarette adaptor, I got dissappointed and set it aside...
TeslaKen
Ken
Overland Park
Currently Occupied
If you did that, wouldn't you want a much shorter cord than the 6' usb c cord listed above? I haven't decided yet if I am going to do the tap in method and have cord tucked up for when it is needed or do what marsh1 did and simply plug it in when I need it then unplug and put coord away when I don't.
