- Ace
- Jan 22, 2025
- Arizona
- 2024 foundation AWD, 2024 model x
- Trauma Surgeon
But that means there is a usb power option in the frunk also. Isnāt that what runs a usb port? 5v?Got them installed finally. THIS TRUCK! Is anything predictable? I was tapping into the existing Frunk light so that it would work with the opening and closing. What voltage would you expect? I had read that everything was 48v. Then i found a few points that were 12v. Well guess what, the frunk light is 5V. 5volts! Why would a light be 5 volts. the puddle lights are 48, the interior lights are 48, the license plate light is 48v. but the frunk light is 5! anyway, i had to put in a relay, and then it was trouble finding one that would fit between the outer and inner panels. finally got it in and working. Its very bright and very helpful and comes on when you open the frunk, and if you don't want that much light you can turn them off manually.
