- Oct 3, 2020
- Western Washington, USA
The Festool FEQ-Plus RO 150 (150mm = 6 inches). I use it on the highest speed with a light touch (heavy pressure will just cause the hard metal to dull your abrasives really fast) and I've experimented with going back and forth between the two modes, but I can't remember which one I found more effective. Any random orbit sander with a 5mm orbit should work as long as you have the right abrasives on it for what you are trying to achieve.Awesome! Thanks for the details. Which sander at which speed did you use for it? Did you practice on anything before starting the truck?
I didn't practice first, I just took it to the truck and started sanding. It's really hard metal so it would take some seriously negligent actions to do any real damage. Taking a grinding wheel to it would fall in that category.
Do keep in mind that you will be sanding the protective passivation layer off so you will want that to re-establish itself before exposing it to oily fingerprints, salts and other harsh chemicals. You can either wash it and let it self-passivate, or apply citric acid or CitraSurf 77 afterwards.
