- Gus
- May 22, 2021
- Austin, TX
- 1981 DeLorean, 2024 Cybertruck
- Occupation
- IT Specialist
I held down the wiper button until it all pumped out. This took surprisingly longer than I expected, but it was just a couple of minutes. Then I had to hose down the front end, because, yuk.Can you please explain how to drain the washer fluid tank? Syphon?
Also, the OM says to avoid water repellent type fluids, but you don’t seem to be having any of the problems it mentions.
The OM also says to only use ethanol based fluids, but I’m having trouble finding any. Suggestions Anyone?
I've been experimenting with different washer fluids but haven't found a standout. I did not like the RainX washing fluid, even though I'm a fan of the coating.
AFAIK all automotive washer fluids contain alcohol as a cleaner/antifreeze, and many use methanol which is poisonous to ingest. Ethanol would have similar performance, but is not poisonous, and will get you drunk (which is probably why methanol is usually used).
I think it goes without saying (although I seem to be saying it) that washer fluid should not be imbibed, regardless of composition.
