New update broke my sound system
Kryptek
Alaska
The newest holiday update broke my sound system, the bass is pathetic compared to the day before!
I have moved the bars, moved the location of sound and tried different music sources Apple, tidal etc..
I doubt this has to be from our -35f temps in Alaska. Can anyone report the same bug?
Or perhaps it needs service?
Did you try a dual scroll wheel reset?
Then try Power Off?
BSDEktelon
Michigan, USA
2024 Cybertruck AWD
Sales Director
Speakers (especially big woofers) are notorious for changing response in cold weather, as the rubber around the cone gets cold and stiffer. I'm in Michigan and I also experience a change in sound when it's cold outside. It can sometimes take up to an hour of the truck being warm for the rubber to soften up and the speakers to sound the same.
Super nerdy, but this is what's happening:
Kryptek
Kryptek
Alaska
I think it’s the -35f temps, they can make the speakers stiff and the sub won’t have the same ohm range. Will get cab to 80f for 30 minutes to test
Kryptek
Kryptek
Alaska
I’m pretty sure it’s the temps guys, the subwoofers thin membrane gets very rigid in below freezing, that limits the amount it can reverb and push air thus lowering power and decibels
Cybertruck26
Chris 🇺🇸 🇮🇪 🇨🇦
Bay Area, CA
Cyberbeast (07/2024 delivery)
Veteran, Engineer, Space 🤓
Thanks for runnin test and getting back to us. How is your battery performance up there? Just out of curiosity.
Kryptek
Kryptek
Alaska
I’m at 17k miles and avg is 426kwh
electricAK
Haines, Alaska
Cybertruck dual-motor
Ahh dude, exact same thing happened to me and I made a nearly identical post yesterday.
So glad you brought up the cold. It has been below zero here.
Makes sense.
