No washer fluid at the blade - solved
Jason B
usa
I can see that while you have the button pressed it doesn't spray on the way down, I assume you are holding the button down the whole time?
stevem
Steven
New Jersey
Cybertruck AWD
Software Engineer
Ended up taking off the elbow connection at the arm base. While connected a flexible tube to it and running wiper on wash, this is how much water sprayed from two swipes.
In my case there is no pressure at the nozzles and it kind of leaking out rather than sprays.
If anyone wants to do the same and measure pressure or amount of washing fluid, just take off the cap from base of wiper arm and connect any flexible tube with fittings diameter.
Mine is going in Monday for lack of windshield cleaning. And I measured mine the same way. And I got 1 oz of fluid per wipe. Just FYI.
Tesla Cybertruck No washer fluid at the blade - solved 1738954398551-1q
I would say 1oz is the maximum. There is additional backpressure from being squeezed through the pinholes.
stevem
Steven
New Jersey
Cybertruck AWD
Software Engineer
Confirmed! And the 1 way check valve in the arm. But someone else on this forum measured his by unhooking the squirter off the base of the arm and run a tube to a catch vessel. So I did the same to compare.
To actually measure the amount dispensed, you'd need to run the tube to a different blade in a bucket. I wouldn't want to activate the wiper without the blade installed lol
Nick
Massachusetts
'24 CT. '21 MYLR.
It is annoying how much the wiper doesn’t help to remove the salt sludge that gunks up and smudges windshields anywhere it snows. It’s an essential function in the winter and it’s just not meeting the mark.
Service looked at it and seemed to wipe my windshield manually because it was clean when I picked it up but that was the only difference because it performs no better.
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
I am wondering if blocking a couple of holes on the lower part of the arm would solve out issues...
