Only Stupid Questions
Cyber1qhorsey
MARK
Los Alamos. NM
FORD Expedition, Escape, Jeep Grand Cherokee
I know, that I don't know, anything.
1. I haven't driven a Tesla. So, how does one safely engage it to move forward or back directions?
2. Does it have a Park setting, on hills?
3. What kind of tutorial does it come with? If I rent one, to learn more, what is the learning curve like to drive it safely?
Cyber_Dav
So Calif
Toyota Siennas (2)
A tutorial! Great idea. Probably some on YouTube... think I'll go check. :)
Okay, try this tutorial. It answers your shifting questions. Simple, but good info.
Thanks for suggesting that, I now know more than I did!
1)There is a shift lever. Your foot must be on the brake for it to actually "shift".
2)Yes. It is an electrically engaged pawl. There is also "hill hold" mode. You don't have to keep your foot on the brake once you have stopped. This is not the same as Park,
3)Yes, there are tutorials available in the car on the touch screen display.
It will take you 2 minutes to get used to driving it but it is, of course, nice if someone can walk you through the few things you might not pick up right away. Unless you live in one of the states where Tesla can't sell the Tesla delivery people will go through these when the car is delivered.
Go to PlugShare, find a nearby Super Charger, go there and ask some questions. You will probably find someone who will tell you more about Teslas than you ever wanted to know.
Cyber1qhorsey
MARK
Los Alamos. NM
Can a anticorrosion under treatment be applied to a Tesla?
I don't see why not but undercoating is pretty high on the list of things that would-be car buyers are warned not to be taken in by. I will say that Tesla is the first outfit that I have ever bought a car from that didn't try to talk me into it.
Saskateam
Aron
Saskatchewan Canada
With a stainless steel bottom I am not sure you need anti corrosion under treatment. The suspension and axel components may be the only things that could corrode.
Cyber1qhorsey
MARK
Los Alamos. NM
So at a minimum one needs to keep exposed surfaces clean. The CT undercarriage is probably, mostly, 301 stainless. Then, there's the battery frame, motor controls motors, and power couplers as well.
I'm thinking this wasn't such a stupid question after all.
Saskateam
Aron
Saskatchewan Canada
You are right that salt will corrode stainless steel. It is a longer time to corrode the metal. A lot longer than the steel used in an ICE vehicle. You should be able to use an undercarriage washer to handle the salt in the spring or raise it to 16 inches in the car wash and spray it down.
Tesla Cybertruck Only Stupid Questions 7DE92BD2-5807-4C48-BAF3-37C9DC8D1C81
Quicksilver
Charles
Alabama
Nissan van
Retired military
Re......undercoating. In a lot of the YouTube videos that show people disassembling Teslas there seems to be a lot of screws located on the (mostly) flat bottom of the vehicle. Undercoating would fill in all the slots in those holes making it difficult to remove the battery and other parts for service/replacement. You could prob coat all those screws/bolts with something to keep the coating from sticking to them but that requires extra labor. And if there are smaller panels/hatches those would have to be masked off to keep from sealng them in. Has Tesla even mentioned that in their PR releases? Def food for thought.
Mule Ferguson
Mule
North Wilkesboro, NC
Model X, Model P3D+, F150. Cybertruck Tri Motor
House Husband
The hex head bolts that hold the quarter panels on (X) are protected by a snap in door so no worries about those.
All these fasteners are going to be hex or star head. Even with undercoating there shouldn't be a problem pushing/wriggleing a socket over them. But in any case undercoating will probably be as un necessary in these cars as it is for any other modern production car.
Cyber1qhorsey
MARK
Los Alamos. NM
Recent blog posts from Seeking Alpha raised the knotty issue of Tesla's Capital Expense (CAPEX), burn rate in the face of Covid-19. To be brief, Tesla will soon hit the wall, if no cash flow accrues from Giga-Fremont and -Reno product restarts. The Stupid Question is: Why can't Tesla see that it is self cannibalizing sales between model 3 and Y, and between the unnecessary X and Y? With model Y available, personally I would never buy a S, X, or the 3! With Cybertruck available, I would never buy an X! To survive Tesla now needs to rapidly differentiate its products to the Y and CT almost exclusively. Given that, there is no need for extensive CAPEX or long delays for a new CT plant,! Ergo: CT PRODUCTION NOW!
