CarPlay Rearview Mirror - Power Tap
shuakin
Josh
Metrowest Boston
Model 3, Model Y AWD, Cybertruck AWD
I followed the everyday chris video to remove the mirror and to open the autopilot housing. Inside there is a red and black wire 2 pin connector. I found the connector in the tesla schematic and ordered parts from digikey to make an inbetween connector. This connector then "T"'s the red and black signals to a DC barrel jack. This way if there is an issue in the future I can totally disconnect the power and voltage step down. Here are some photos of the process.
Below is the cable assembly. It is about 2-3 inches in length which was just enough to exit the housing cleanly.
Tesla Cybertruck CarPlay Rearview Mirror - Power Tap IMG_1107
Tesla Cybertruck CarPlay Rearview Mirror - Power Tap IMG_1106
Tesla Cybertruck CarPlay Rearview Mirror - Power Tap IMG_1113
I disconnected the red/black wire housing from the clip in the triangle cover. Then put the dongle inbetween the two connectors. Then I closed it up without pinching any wires.
Tesla Cybertruck CarPlay Rearview Mirror - Power Tap IMG_1139
The DC barrel jack sticks out, I can use some black electrical tape or 3M tape to secure it if it bothers me. So far I don't notice it.
Tesla Cybertruck CarPlay Rearview Mirror - Power Tap IMG_1140
I tested the power to the Jomise G814-pro rearview mirror. It uses 0.8 to 1 Amp at 5v.
Tesla Cybertruck CarPlay Rearview Mirror - Power Tap IMG_1141
The jomise has some straps to hold it onto the mirror. However there is a little gap behind it. So I used some foam padding that came with the jomise to cushion it and prevent rattles. I wrapped the excess cord around the mirror and used a 90 degree usb-c to keep it out of the line of sight of the autopilot mirror.
Tesla Cybertruck CarPlay Rearview Mirror - Power Tap IMG_1142
Tesla Cybertruck CarPlay Rearview Mirror - Power Tap IMG_1143
The screen is pretty good. When it powers on it normally enters Car Play and the last app you are using. I like to set it on Waze to be alerted of traffic data along my route. There is a rearview camera that plugs into the mirror which I need to figure out where to route next. I am thinking of placing on on the top trim of the truck bed (the piece that is removed when you install the cybertent). Any tips or tricks on how best to route this please let me know.
shuakin
Josh
Metrowest Boston
Just went for a first drive with this. The mirror appeared to lose power during the drive. So 1 Amp draw may not be capable on this circuit.
shuakin
Josh
Metrowest Boston
I am suspecting the issue is with the DC-DC converter I am using. I am going to try other versions.
nasg
Nas
Detroit
Beast
really interesting, let us know how it progresses.
shuakin
Josh
Metrowest Boston
AO-Pete
Pete
Dallas/Fort Worth
abstractocean.com
Founder & CEO
@shuakin would you mind sharing the part # for the white plug & socket?
shuakin
Josh
Metrowest Boston
Thr mirror voltage is not enough to work with Review Camera mirror
Yes, this may be the case, I am going to try a better step down voltage translator to see if it cleans it up. The first one I had was a generic one.
FuryEV
Cybertruck AWD and Cybertruck Beast
I got tired of messing with it. and just did the
OBD2 to Cigarette Lighter
works perfectly
shuakin
Josh
Metrowest Boston
works perfectly
Does power turn off when you leave the car when using OBD2? or do you have to manually turn off the load?
