Rear screen is there a way to control climate?
jeevesbond
Rajeev
usa
rivian r1s
Hi all. In the model x rear screen can control rear climate. Can you do that in cybertruck. I can’t figure out how.
Yes. My kids do it all the time. Make sure “sync “is disabled
Reactions: REM
jeevesbond
Rajeev
usa
rivian r1s
To
Clarify. Are you able to have them
Change temperature etc on rear screen or just control vents and air speed
I’m in the x right now but will check when I get back to the truck. I think it has its own temp zone just like the x
jeevesbond
Rajeev
usa
rivian r1s
Seems our rear screen has no temperature control only vents, speed vent on and off. Is that accurate?
Qixer01
Joshua
Hope Mills, NC
CyberTruck
To
Sitting here now, Looks like only fan speed and direction for the vents can be changed on the rear screen.
I stand corrected then. Sorry if I misled. My kids do tinker with it all the time.
Reactions: REM
jeevesbond
Rajeev
usa
rivian r1s
Ok
So seems that you cannot change temperature then? I had an hvac issue and had a humidity sensor replaced was confirming tjis isnt an issue
Separately truck going back to svc due to the critical rear axle steering issue. Heard its a issue w a psc or something. Figured if hvac an issue id have them check at svc center
Reactions: REM
PungoteagueDave
David
Boynton Beach
Ok
Holy cow, don’t tell REM there’s a missing feature.
