- May 27, 2024
- SE Michigan
- Cyberbeast
Sure, and adding 48V LFP batteries to the trailer maximizes total payload.Ok, then maybe in addition to those panels, your trailer in that circumstance needs to be carrying a tank of propane and the ability to convert that to juice. Or an additional battery like the pebble idea.
Point is still that the solution would be customizable to your particular range dilemma rather than force an entire fleet of cars to carry a battery as a solution which solves the problem for the one owner who chose to tow an 8x32ft trailer but not for those who have a different range problem to overcome like towing a boat to and from a lake which is not that close to a supercharger, or making it across BC to the next charger on an Alaska trip or making it to a remote job site with enough juice left to power your construction equipment etc.
Customize the energy supplementation to the particular problem.
Can also put the LFP in the truck bed and/or frunk.
5kWh per 100 pounds. Nice and modular. Super easy to integrate if you can deal with 11kW charge transfer rate (inverter to wall connector) or 7kW (inverter to mobile connector) while stationary.
Theoretically, the current PCS charger could handle 48V - 320V DC input and provide stationary or in motion charging (disables outlets though).
Otherwise add on 48V to 800V converter.
