Safest/best way to carry propane in a Cybertruck.
I don’t have much experience traveling with anything other than the tiny little green bottles but fire bans have made me want to carry a larger amount. Was thinking of bringing a little 5lbs tank I got from a friend for Christmas or maybe even the 20lbs tank I use for powering our back yard pizza oven on our trips.
what’s the safest way to do that? In the vault? Is it safe to close the tonneau? It’s gets pretty damn hot in there during the day in Arizona. Any of you have clever packing or mounting solutions you’d like to share? Any tips?
Suppliers recommend under 120F and out of direct sun. So partly closed vault with the tank at the front might be ok. It's also better if you don't have the bed dust sealed so the heavier than air propane can escape if the tank vents.
That makes sense. By front do you mean the tailgate side or the window side? There are some weird semantics to do with truck beds and those descriptors.
Loudness
Jay
Atlanta
Cybertruck (AWD)
The only truly safe place is in the bed with the tonneau open, strapped into a carrier so it's upright and can't roll around, or in a hitch carrier. The primary reason is because of potential leaks, you don't want it leaking into an enclosed space, especially the cabin.
And as @mongo noted, you have to keep it under 120°F because like everything else, propane expands with temperature.
I have my Boring Company not-a-flamethrower mounted in my frunk, but with an empty tank for show. I thought about keeping a spare small tank in the truck, maybe strapped to a molle panel, but decided against it.
Hitch carrier is a solid idea. I bet that’s problematic in a collision though no?
So does it help if the tank isn’t full? Let’s say at 80% or so (totally thumb sucking that number) to accommodate for heat expansion?
Loudness
Jay
Atlanta
Cybertruck (AWD)
Yeah, but at worst it's a propane fire/explosion outside of a decently protective steel tailgate :)
Probably wouldn't be good for anyone that hit you, though.
I don't have any direct experience with them. so this isn't a recommendation, but you can get them pretty inexpensively on Amazon. Here's a couple I found:
https://www.amazon.com/MaxxHaul-70108-Aluminum-Carrier-Receiver/dp/B008CE0LIC/
https://www.amazon.com/WEIZE-Carrier-6-Inch-Capacity-Folding/dp/B0CX1X2WXF/
You could combine it with one of these and strap it down:
https://www.amazon.com/Propane-Cylinder-Camper-Travel-Trailer/dp/B0BKY3GYM9/
I was think glass end for shade and securement.
I'm may be doing this to adjust trailer tongue weight.
