Gurule92
- Sep 2, 2021
- Colorado Springs
- MYP
- "Cyber" stuff
Prison wallet would have been cooler, we already have the "open butthole" voice command.Confirmed: “Smuggler’s Bay” nomenclature for the underbed storage
42.9 kwh / 100 mile calculated to 2.331miles/kwh?The variables tesla uses for incentive calculations
833.33 miles per month
13000 miles per year
26 cents per kwh at supercharger
$3.30 per gallon of gas
Wireless charging is a step toward Driverless Taxi using Full Self DrivingSo I jumped into the javascript on the CT pages to see what i could see. There was a bunch. I may not have interpreted any of this right so take it with a grain of salt.
Foundation series option info (code $FS00):
Looks like there will be two steering wheel options (squircle and round probably [which i think is default]?).
I am going to assume that the wireless charging one is the normal one, but it would be weird to have in this section right? ** Conjecture time... what if the diaper holds a wireless charging option?? **
Notice how the base options dont have WC01 (wireless charger)
CYBR = either powershare or just being a cybertruck not super sure
APBS = autopilot basic system
ST04 = squrikle steering (could be round i suppose)
MTC03 = dual motor
TW01 = tow hitch
SC04 = supercharger network access pay as you go
WH0B = 20" Cyber Wheels with 35" Tires"
CPF0 = Standard Connectivity
Squirkle name confirmed
20" rims have these tire options: (All terrain with aggressive tread, or a street?)
When you select a trim, it sets the option for that trim and unsets the options for the other trims. Does this mean there are 5 trims?... 2 founders, + 3 we know
3 4 and 5 are the ones we know?
"trims": {
"$MTC03": {
"variant": {
"code": "DM",
"name": "Dual Motor"
"configurator": [
"included": [],
"optional": [
"$APF2",
"$APPB"
"upgradable": [],
"base_options": [
"$MTC03",
"$CYBR",
"$APBS",
"$ST04",
"$TW01",
"$SC04",
"$WH0B",
"$CPF0"
"combinations": [
"$IG01",
"$IW01"
"$MTC04": {
"variant": {
"code": "TM",
"name": "Tri Motor"
"configurator": [
"included": [],
"optional": [
"$APF2",
"$APPB"
"$LB01"
"upgradable": [],
"base_options": [
"$MTC04",
"$CYBR",
"$APBS",
"$IW01",
"$ST04",
"$TW01",
"$SC04",
"$WH0B",
"$CPF0"
"combinations": []
"$MTC05": {
"variant": {
"code": "RWD",
"name": "Rear Wheel Drive"
"configurator": [
"included": [],
"optional": [
"$APF2",
"$APPB"
"upgradable": [],
"base_options": [
"$MTC05",
"$CYBR",
"$APBS",
"$IG02",
"$ST04",
"$TW01",
"$SC04",
"$WH0A",
"$CPF0"
"combinations": []
"toggle": [],
"default_trim": "$MTC05"
"fees": {},
which means that these are the founders?
V2H is a "Core" option, i guess this means standard
MTC01 and MTC02 have interesting delivery timings (These must be the founders series)
Range extender requires service center install and will likely be available end of next year. also, this is where the 16k thing came from
In the range extender area, there is a 470+, 425+ and a 450. do we know if it can go on rwd? Would make sense i guess
Looks like youll be able to add all the random shop accessories when configuring via premium accessories package (This stuff will likely have 3rd party knockoffs quick)
1 240 and 2 120 outlets in bed, two 120 in the cabin and two aux power connections with 2.3kw output (probs frunk and roof)
Full code:
I'm sure there's more. but I need to do my real job now. someone have at it
NO, definitely NOT. While technically possible, this is against, like,... EVERY rule in the book when wiring a house, and for good reason. Breakers, rules, wiring, (oh my!) would all fail.mobile powershare connector (Does this mean it can backfeed to nema 14-50 and normal house outlet?)
Where my electricians at?
okay, so maybe not the normal house plug but arent there nema 14-50 sockets for generators to plug into?NO, definitely NOT. While technically possible, this is against, like,... EVERY rule in the book when wiring a house, and for good reason. Breakers, rules, wiring, (oh my!) would all fail.
Let me know if you want a breakdown as to why.
