Kryptek
- Apr 1, 2024
- Alaska
- Cybertruck AWD Gray Interior VIN 4xxxx
- Thread starter
- #1
All my own fault!
Rescued by my friend with a heated garage!
I was at 30% yesterday evening as we were deep into a cold snap ? in central Alaska .
I figured I could get charged up the next morning and start my errands around noon?
I drove to the local 48kw Flo charger ? in town at 1030am, battery was 24% on arrival with snowflake
Plugged her in and for the first time on display it read something like
battery ? heating up to charge, charge will start in 3:45 hours, 2 hour charge remaining.
I let it sit on that display for about 5-8 minutes hoping it would go away & just start charging. But I also had a voice in my head reading 21% remaining that you might need to seek a slower charge but in a heated garage.
I frantically texted my buddy who lives about 18 miles away and let him know I might need his help. Informed him my dumbass let the battery deplete too much and it would not charge in -30f. I have not had this problem at -20f but I have also never let it below 40% prior to this case.
He let me know that I could use his garage and I quickly did so with the headlights off no climate control & no music! I’ll tell you it was a cold twenty five minutes! I arrived with 11% from 21%. I was lucky and my estimate was right about the heat helping! Even with just lvl1 at 12amps @1kw it took to a charge!
I ended up socializing with his family while he worked for about 6 hours which put me back to 23% and removed the snowflake
. It was dinner time at my home and I made a mad dash 18 miles home at -33f once again no heat but with headlights because it was dark now. After about 4 miles my windshield began to fog ? heavily, obscuring the road I had to turn on my hazard
lights and luckily a gas station was near by allowing me to stop. I then turned on climate control and defrosted the windshield! Thank Elon for such speed and heat! This would have taken 5 minutes in a regular I.c.e vehicle, it took about 1 minute to start clearing up. Got onto the next freeway ? ramp and 12 miles to the charger! I made it to the charger with 12% remaining and had an issue with the Flo station. I moved over one space to the unit I’ve never used and it was working, so after about 5 minutes deciphering the 1st and moving to second stall charging began and the snowflake
was back but it immediately started at 42kw like normal and slowly made it to 48kwh and 90mp/h
So I’ll never let my soc% drop that low in cold weather ever again! We are going to climb back into plus zero temps after this weekend but I doubt this will be my last with such an extreme this season once more.
