Tilted / lopsided rear end suspension (passenger side is 3/4" taller & higher than the driver side)
Hims3lf
Jeff
CyberTruck
The rear passenger side is 3/4" taller than the driver side. I have changed the height from entry to high and back again but it stays 3/4" taller. Air pressure in both rear tires are the same. The 3/4" difference stays when at its highest and lowest
Tesla Cybertruck Tilted / lopsided rear end suspension (passenger side is 3/4" taller & higher than the driver side) 1000008801
Tesla Cybertruck Tilted / lopsided rear end suspension (passenger side is 3/4" taller & higher than the driver side) 1000008802
CT007
FS Cybertruck, X plaid, YP, S LR, 3P
That title really threw me off
Is the truck level?
Could it be the normal difference to handle road camber?
Nidavellir
AWD CyberTruck
Try putting it in camp mode and then switch back to normal mode and see what that does
Hims3lf
Jeff
CyberTruck
Still no luck. I have a service appointment in a couple Weeks
DerekCyber80s
Derek
Roseville
Teacher
I have same issue now. Right rear is lower than rest of truck.
Hims3lf
Jeff
CyberTruck
after months of trying to get this fixed, Tesla service says it is "within spec" and will not fix or troubleshoot the issue
Hims3lf
Jeff
CyberTruck
I posted something on X about this to see if people can measure their CT's to see if they have the same issue. I have measured about 10 CT's and none have this issue.
Shrey
Shrey
CyberBeast
This sux OP. Sorry this has happened to you. Ive not heeard of this issue - Can you take it to another SC? Ive taken it to 4 different SCs over the the 6 months of owernship with varying degrees of help. Thats my suggestions.
Measure and record while the truck is parked in the exact same spot, but oriented 180°. This will compensate for a sloping concrete pad.
Also, it may be a difference in your panel alignments. You need to measure from a common plane, like @mongo above pointed out.
