Unforeseen Technical Difficulties with my Cyberbeast
jingo112674
Emmanuel
Houston
Tesla Cybertruck, Ferrari 458, Lexus GX
Surgeon
Recently, I have encountered some perplexing issues with my Cyberbeast. On two separate occasions, my Cybertruck unexpectedly ceased operation, only to restart after approximately 2-5 seconds. Thankfully both incidents occured while I was parked, mitigating potential safety concerns. Has anyone else experienced similar issues?
Bjhracer
Brandon
Evansville, In
Model 3 performance, model Y, Cybertruck order
Retail
It will turn itself off if sitting parked for a duration of time. You wake it back up by hitting the break. Not sure if this it what you are referring to, but very occasionally my model Y would need a software reset by holding steering wheel buttons. Have t had that issue in Cybertruck yet.
Reactions: REM
jingo112674
Emmanuel
Houston
Surgeon
It started happening more frequently when it's parked.
Art138
Art
Weston,Florida
MYP,Ford GT & FS CYBERBEAST
Next time look at your app after you park and see if it says sleeping. I have parked mine and after 15 or twenty minutes reads sleep on the app. Upon opening the door the truck wakes up.
jingo112674
Emmanuel
Houston
Surgeon
Thank
Thank you for the recommendations. I will definitely try that.
If you lean over the center console you can deactivate the person present switch in the seat and the truck will shut down.
Needs a SW patch, me thinks.
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
The truck shouldn't just suddenly shut down, especially while driving. Are you talking about going in to sleep mode while parked? Just wanted to make sure
Not while driving, just while parked. Happens to me a lot when messing with nav and apps.
Also reportedly happens on cars if reversing with the door open and twisting to look backwards with seatbelt off, then it drops into park.
