slomobile
- Dustin
- Apr 7, 2022
- Memphis
- Cybertruck
- Roboticist
- #16
Valid point. They will wear unevenly to each other, but evenly within the same pod. Being smaller, thus cheaper than a full pack, on wheels, and quickly removable, we've reintroduced user swappable batteries. Its like having a powerwall unit under each seat. Have a spare at home, another at work, just in case. Grab them all if taking a road trip. Leave most of them home for weight savings if you are hypermiling your commute.Battery modules with different use levels wear at uneven rates, and trying to use them together damages weak cells more.
With the current battery chemistries, it's not not a good idea to make packs modular like that. You 'pod' battery would have to be used more like a battery recharger than as part of a larger pack.
Otherwise you will have significantly shorter battery life.
They do not need to function as a unified pack. Quad motor, quad seat, quad battery. See where I'm going? Redundant cooperative systems. A 5th or 5th and 6th chunk remain with the vehicle to fill in for the first pods to drop below usable levels. A wheelchair user would wear down his pod much more quickly so he can swap his seating among the other pods to even out wear.
Don't look at it as swapping groups of cells within a pack.
It is a pool of packs at various SOC and SOH. Each with their own BMS.
And a pool of loads.
The vehicle is a match maker and switcher.
Each load(except the individual seat loads built into each removable chunk) is capable of running from any pack, and being switched from one pack to another when stopped at a red light.
