Delusional
- Phil
- Dec 5, 2019
- Pittsburgh
- F-150
- Construction
- #1
To me the two biggest questions always were....
1. How thick is the stainless? And that turned out to be a third less than expected.
2. What battery chemistry is it? I really don't have an answer to that. I know the range turned out to be about a third less than expected, but why?
On that battery day a couple years ago they definitely mentioned that they would be putting "high capacity" 4680 cells into the cybertruck, and that means a chemistry that includes cobalt.
But if they are using an iron chemistry, that would explain the shorter range.
Personally, i would prefer Iron because that means thousands of charge cycles, and much reduced fire risk. I suppose the dry anode would reduce fire risk. Ideally, you would order the chemistry of your choosing, with at least two choices.
Maybe this information is out there somewhere, but I have seen zero mentions of actual delivered battery chemistry. I don't even know for sure if they are using the dry-coat anodes and cathodes.
What is up with that?
My guess: They can do the dry anodes with the more stable Iron chemistry but are still having problems with higher capacity chemistries.
