Wheels locking up on regen braking?
Rippin1Gear
MJ
Seattle, WA
Foundation Cybertruck
plumber
Curious does anyone else have their wheels lock up like abs braking kicking in coming to a stop on wet roads? Have had this happen a few times now. Manual driving, coming up to a stop sign in 25mph residential streets, and just regen braking. Within about 5mph or so 10ft from the stop sign abs feels like it kicks in and wheels lock up and slide the truck. Never had this issue with out M3 or MY. Haven’t tried with FSD yet to see if it’s replicated.
Coaly
NE-PA
Ford Ranger, Escape, Model T
No, 2026 model year here that doesn’t stop that quick. If I let off accelerator too late, I need to use the brake pedal. Never hard enough braking in regen to break traction. Even then abs doesn’t kick in. Only had that happen on packed snow covered roads. Then I chose slippery surface, and all wheels turning the same speed is smooth.
High air pressure would cause what you’re describing, or shitty tires. (Hard compound like Michelin uses)
