misdemeanor
Kentuck-lette
www.TeslaKY.com
‘25 CT, ‘22 YLR, ‘22 3LR
All. The. Things.
Special thanks to @Wolfbox for sending me this to review!!
Wolfbox G900 Tripro digital cam: https://amzn.to/4kvGnfA
Here's a link to all of Wolfbox's Prime Day sales!
Here’s a comparison of the CT mirror vs this Wolfbox digital mirror
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2895
Here’s the cigarette power output.
I tried to power the mirror going straight to the USB-C port in the center console, but it never powered on.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2897
For testing purposes I powered the camera using my ecoflow and it was pulling 12W
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2907
Mounting the camera was the first task and I will say that it was not meant for the small mirror in the CT. These rubber bands will not hold the weight of the camera in place especially on the smallest bumps. I think they need to create an actual mount for the CT.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2898
The camera’s interface is really responsive and I can confirm the audio commands work, but this was with a quiet cabin (no music or road noise).
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2899
Here’s a split view of the front and rear video feeds. Both of which were very fluid with no delays.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2900
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2901
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2902
Being able to review footage directly from the mirror is really nice too. You can select the feed on the left, then select the date/time stamp of the event to review it.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2903
The kit also comes with a GPS module to record direction and speed.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2906
The rearview camera is intended to be installed at the rear of the truck, but the top of the bed is the best placement for it. The red wire you see there is supposed to connect to the reverse lights, but I don’t think I’ll be wiring that in.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2910
Here’s a view of the CT’s interior cabin camera. I’m not sure if it’ll affect FSD because I know it can be very sensitive to the driver having a “device in hand”. Again, I think they need to create a custom mount for the CT that will place the mirror further forward so it doesn’t obstruct the cabin camera.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2908
Here are the different resolutions you can choose for the camera feeds.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2909
Another thing to note is the front facing camera is adjustable.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2896
LandShark
Sacramento
Cybertruck AWD
is there a way to hardwire this mirror? i dont like the cigarette lighter power thing
misdemeanor
misdemeanor
Kentuck-lette
www.TeslaKY.com
All. The. Things.
They do have a hardwire kit. This is what they sent me, but I haven’t got around to trying it out.
You can use the hardwire kit to connect the dash cam to the fuse box.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review 1751849058737-7a
BrockN
Brock
Kamloops BC Canada
I'm not seeing anything that suggests they realize the Cybertruck runs on 48 Volts. I would be careful about what I hardwire it to.
Geebz
you can build a better looking wolf box system using the including kit with some modifications.
hardwire: Pull apart the cig lighter and mount the board on the inside, side of the CT housing cover. Remove any excess light cable length and fuse parts. Pull the 12v from the pins on the inside connector.
year apart the factory mirror and use the arm connection to the wolf box mirror housing.
enlarge hole on mount to route all cables
mount the camera on the roof
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_9217
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_9223
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_9222
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_9256
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_9224
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_9255
tide80
Thomas
Santa Cruz, CA USA
Cybertruck AWD FS
I found that I can power the Wolfbox G900 in my CT using the USB-C ports. However, you must use a Charging Cable USB-C to USB-C Data Blocker Charge-Only Cable No-Data. These have no data transfer wires in them and thus have more room for the larger charging wires. I used a "PortaPow USB-C to C 5ft Charging Cable with Data Blocker $7" that I bought on Amazon. I have had no problems. Here is what Wolfbox support told me. "You can consider using another USB power cable as long as it meets the following requirements: The voltage of the USB port is 5V, the USB cable without data transfer mode, and both ends comply with the PD protocol."
Geebz
Only problem with using USB is that you have a bulky mess of cables. So much easier to just get the power right there at the mirror.
reaction26
Arash
CT, MXP
Program Director
@Wolfbox Great pics and install. I actually did 3D printer of 2 did things together. (1) OEM tesla mirror and then (1) WOLFBOX model Y mirror backend together. It works great. See pics.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2712
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2706
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review IMG_2709
tide80
Thomas
Santa Cruz, CA USA
Cybertruck AWD FS
Yes, you are correct. I installed my Wolfbox just above the screen. That way the 12" width of the Wolfbox did not interfere with my sun shades. I removed the factory rear view mirror. I really like having the Rear live display immediately above the CT display.
IntoTheRain916
Kai
Sacramento
Model Y, Cybertruck
Business Owner
I just want to say how much I appreciate the build quality and user-friendly controls on this unit @Wolfbox . I've tried two of the cheap overseas brands that YouTubers constantly push—and let me tell you, the difference is night and day. If you're not using WOLFBOX, you're doing it wrong.
This isn’t a full install guide on a Cybertruck, but here’s a quick rundown on what I did: I mounted the WOLFBOX G900 Tripro onto my OEM rearview mirror (straps not needed but I like them and I used short ones), routed the cables up and over, then out through the OEM grommet used for the lightbar—and finally mounted the rear camera on my Marsag.co rooftop tent. Had trouble with clearance with the Wolbox rearview mirror but USB-C adapters angled nailed it. This was a lot of DIY work to make everything fit cleanly, but once dialed in, the setup is absolutely unmatched.
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review 20250714_191838
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review 20250701_192929
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review 20250706_144146
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review 20250630_172223
Tesla Cybertruck Wolfbox G900 Tri Pro Dash Cam Review 20250714_191835
Wolfbox
Florent
That looks nice! Thank you sharing! (y)
