We've been thinking about something like that, but we need to get that wired in somehow.
Was thinking the best place to house wiring would be under the sail panels where the lightbar wiring runs
“With respect to the over the glass part, I’d want something that capitalizes on the mounting points (I have heard two on the non-FS, not sure if that’s true). A mechanism similar to tesla’s cross bars. Quick and easy to unclasp”
I like this idea better than the small frunk lid, but wind noise mitigation would need to be addressed.
yeah. I think if you had a softish surround like a big gasket to seal the space between the panel and the glass roof you could keep it from being noisy or more importantly aerodynamically impactful.
btcrealm
Brian
Virginia-ish, USA
btcrealm.com
cybertruck
NOC
As to the question about the mount points on Non-FS vs FS.
It has been confirmed that all 8 of the mounting points are there by people on here. The Non-FS 'sail' portion on either side of the roof window do not have the holes in them that open to show these mounts. A FS series sail piece can be ordered through the service center was the determination/solution in another thread.
I will try to remember to confirm what I can of this at the Michigan light show later this month. I'm sure there will be standard CTs there as well.
NXTruck
Illinois
X, Bronco, Ambo, Acela
I’d like to see a channel for water along the edge of the windshield. Water could flow in and roll out the sides rather than up onto the windshield.
Guys and gals, happy Hump day! Just launched last night and sold out first batch to our local customers, next batch arriving in 4-5 weeks!
200w Solar hood panels - $699.95
This 200w panel set is a great way to integrate Solar panels into your Cybertruck to charge your portable power station(jackery, goal zero, etc) during daylight. OurKit is purpose-built to fit seamlessly on the hood giving you a fully integrated giving you ultra-efficient charging solution that looks OEM to keep your fridges, dash cam, lighting, phones, etc., charged without draining your vehicle battery.
NO - THIS WILL NOT CHARGE YOUR TRUCK!
Kit Includes:
  • 2 x 100W hood solar panel
  • 1 x vinyl hood decal
Flexible Solar Panel Benefits:
  • Keep your power station charged. The solar panel comes with standard connectors and uses adaptors (buy separately) to charge for most of the power stations on the market.
  • Decreased hood glare. The flexible solar panel features a top-tier ETFE film surface that eliminates light reflection, reducing glare while driving.
  • Convenience and space-saving. The hood flexible solar panel attaches directly to the vehicle’s hood; no roof rack is needed.
Flexible Solar Panel Features:
  • Solar cell: Grade A PERC Monocrystalline solar cells with much higher efficiency and more durability than other mono solar cells.
  • Premium EFTE Film: This film features superior light transmittance and weatherproof performance and is heat, corrosion, and UV resistant.
  • Durability: Cutting-edge tech and robust materials ensure resilience against snow, ice, mud, rocks, etc. Their high durability makes them perfect for off-road vehicles.
  • Ultrathin & Lightweight: At only 3mm/0.12 inches thick, it is lightweight (60% less than conventional solar panels).
Electrical Information:
  • Peak power: 200W
  • Solar cell efficiency: 25%
  • Maximum power voltage: 32V
  • Maximum power current: 4.25A
  • Open circuit voltage: 23.5V
  • Short circuit current: 4.6A
  • Power allowance range: +/-3%
  • Maximum system voltage: 500V
  • Net Weight: 5.5 lbs
  • J-Box: IP 68 rated with 1.5m/5ft cables
  • Values at standard test conditions: Air Mass – AM1.5, Irradiance – 1000W/m2, Cell Temperature – 25°C
Can we please see a picture of where the wiring runs into the frunk and what that looks
Like with the frunk lid open?
Roger@CYBERTRUCKco
Roger
Poway, CA
manufacturing
We have a video that will post on Monday, Tuesday he get a zip tied to the backside of the lift arms
TexasRaider
JR
Denton
Cybertruck + MS
Civil
This is a convenience item. Not everything in life has a payback. Some make life easier. So cost for these products is usually relevant for how much inconvenience it reduces rather than payback. In this case it charges a portable battery so one doesn't have to use the battery from the truck for other uses. Is it for everyone? Nope, but it beats setting up a panel array and putting a panel array away. I am sure Cybertruck Co is working on one for the camper top.
Great job @CYBERTRUCKco!
Great point for context!
btcrealm
Brian
Virginia-ish, USA
btcrealm.com
cybertruck
NOC
Tesla should put a solar panel where the roof glass is. I don't need to look out the roof, just more heat coming in.
It unfortunately wouldn't be efficient/powerful enough to charge the cybertruck. If they were to use it to negate the phantom drains on the system that would be cool though!
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Looks great! I really like that you can use it while driving. When parked, it could pair with the 400w solar blanket I have that fits over the windshield, glass roof, or tonneau cover locations. At the extreme end, could be possible to pair 3x400w solar blankets + 200w hood solar to get 1.4 kWh solar across the entire length of the truck.
Take a look at the GoSun product.
