- Nov 15, 2019
- Cybertruck Owners Club
- CYBERTRUCK
- #1
Some good technical highlights pointed out by @Dazureus (in his post below in this thread):
1. Ring configuration that uses Time Division Multiple Access (TDMA) to create deterministic signals and avoid collisions or packet dropping. The Automotive Ethernet papers I've read talked about internal best master time algorithms to determine a dynamic Grand Master time clock for signal synchronization, but it looks like Tesla might be using a more static time division signal mapping. From what I understand, each sender is assigned a time slot in a frame to transmit their data, so it creates a system wide synchronous transfer. Both methods allow audio signals to be transported around the network without having synchronization issues between speakers that are geographically distant from each other.
2. Switches are connected to the gigabit ring and connect to CAN for local devices. It's a hybrid zonal architecture in that the switches are controlling local devices, regardless of functionality, but they're also translating to CAN protocol within the zonal areas. So they can use legacy devices instead of having to convert everything to smart acuators.
3. Not everything is on 48V, but they looked at the most power hungry devices and worked with suppliers to convert them to 48V. That jives with what I'm hearing about in the company that I work for.
4. Side stepped information on how the extender connects to the PCS. Almost got that info, but steered away a little.
5. SbW front uses 2 powerpacks that power 50% of the load rather than 1 powered and 1 redundant. It also sounded like they distributed sensors between the two rather than having redundant on each. I'm interested in learning more about that. I would have expected redundant sensors on each power pack, then having communications between the two for final value confirmation.
