3rd party alignment
Gigahorse
AWD
Same here. My local DT that installed my tires said they can’t do an alignment on the Cybertruck also.
Might be worth checking again, addition to this one is recent.
Gigahorse
AWD
Interesting. My local Florida Discount Tire said they wouldn’t do an alignment when I called 2 months ago. I will check again.
They recently added the option, worth checking, as $200 is cheap compared to Tesla
mrcarcrazy
2026 cybertruck, 2023 Corvette, 2005 Elise, 1949 Chevy 3100
Omg AI is terrifying. That’s a pretty solid image. The truck needs to be adjusted while sitting on the suspension. One section makes that less obvious.
Noteworthy that Tesla recommends setting the alignment at medium height. I want to check the difference in toe specifically at low, medium, high.
I’m preoccupied with a project truck that will likely have my attention for the next year. But I hope that someone will. I’d be super curious to see how severe the change is. If it’s massive I would argue it would make the most sense to adjust at the ride height you’re on most commonly.
Helpful additions would be:
- place something under the tires to allow for easier movement/adjustment. Some use cheap cutting boards, plastic bags, grease…anything to decrease resistance.
-final check should be done with the jam nuts tightened, and the joints in their neutral position(not cranked over from the jam nuts being tightened).
It’s a daunting task but it really is a simple process. YouTube has videos on it as well.
