WheremaCT@
Joe
Detroit
Recent photo floating on reddit shows bewildering new perspective on the CT considering Elons height. It looks drastically reduced way more than 5%. I might be wrong. But per Google...
Elon is 6"2
Jordan peterson 6"1
And Joe Rogan is 5"8
Tesla Cybertruck New Cybertruck Height Perspective Image  ? ?✂️⬇️ RDT_20220129_1605166469977556265885167 (1)
Tesla Cybertruck New Cybertruck Height Perspective Image  ? ?✂️⬇️ RDT_20220131_0006135169558419300906197
WheremaCT@
Joe
Detroit
Objects in background are larger than they appear.
Very true. But Elon looks like he's right up against the CT. Exception for Rogan being let's say two feet away. Elon could easily glance over the top of the truck. He might be in heels though.
Was no politics until you injected it in your very first post.
Feared it will naturally go there so that was a little disclaimer. Perhaps unnecessary.
Albern
Alex
Toronto, Canada
Per the original specs, the suspension travel is +-4" from it's mid-way point.
Also, with the front tire and Elon as reference points, does anything think that this prototype is wearing 35s?
Deleted member 4261
Guest
Elon is 6"2
Jordan peterson 6"1
Crazy thing is Reddit is unfortunately lambasting the trio and their political ideologies into oblivion without any proper commentary on the new CT size and perspective itself. Even though I know it's a head scratching combination of these three infront of the CT please let's keep politics out of this.
Looks like the rear windows roll all the way down.
There is nothing to say about the size of the truck from this photo. No one has ever changed the height spec so until Tesla says otherwise it is a baseline (minimum) height of 75” with a ground clearance of 8”.
Albern
Alex
Toronto, Canada
I don't recall there being a stated dependency of 8" of ground clearance with a vehicle height of 75". CT's height was a spec at the reveal and clearance can range from 8" to 16". Do you have a source?
Also a few more points of reference:
1: Highest setting vs. lowest setting
Tesla Cybertruck New Cybertruck Height Perspective Image  ? ?✂️⬇️ 1643516934499
2. Elon for scale / Elon my constant (LOST reference)
Tesla Cybertruck New Cybertruck Height Perspective Image  ? ?✂️⬇️ 1643517029814
rizvend
JAKEMBL
cybrtrk, aptera reserved
Nurse Informaticist
SONNYDUT
Sonny
Westminster, Ca
Dual-Motor Cybertruck, Model S, Model Y, Model 3
Engineering 3D Print Specailist
The Ct looks like it's at it lowest level for easy entry/exit. The normal height will be 4" higher which is 12". Off-road mode will increase another 4" to 16". I read somewhere, that the CT could rise as high as 20" for off road purpose. I hope this is the case. It will be awesome! Elon also said it adaptive at high speed, will drop automatically for efficiency. I excited either way.
fritter63
Atascadero
2024 Model X
Wax on, Wax off!
Elon is 6"2
Jordan peterson 6"1
Somebody is LIFTING! (ref: Seinfeld)
:ROFLMAO:
