Anyone else's vault divider's center lift plate not function properly?
CT007
FS Cybertruck, X plaid, YP, S LR, 3P
Even if I don't install it anywhere, the brand new divider I received today doesn't have a functioning center piece (whatever it's called). It always stays up and doesn't actually lock. Picture for description.
Tesla Cybertruck Anyone else's vault divider's center lift plate not function properly? image
CyberKurt
IL
S, X, Cybertruck
There are a few threads on this issue of you search. I did have the same problem and the root cause is the bed panel assembly. Some had it corrected by replacing the floor section, that did not work for me the issue was the side section alignment had to be corrected to allow the floor to fit with correct tolerances. One way to confirm it is not the gate panel is that it will fit correctly over the rear smugglers bay door but not elsewhere. If you make a service appointed saying the gate does not fit they should know what to check and correct.
CyberKurt
IL
S, X, Cybertruck
It will likely not work with a third party Berliner either.
CT007
Thanks. I should have explained better. The center piece which expands the divider to lock in place, does not actually engage even if the divider is no where near the bed. I would assume the center piece would snap into place and lie flat but that doesn't happen with my divider, irrespective of whether I am installing it on the bed or not
BrickBungalow
Ryan
Portland, OR
Tesla 3, Cybertruck reserved
Gamer
I had the same problem. Tesla sent a replacement that works fine. I still have the defective one and am pondering possible ways to use it for something.
Speedr
Dual Motor Cybertruck
It's probably just a bad one. Send an email and they'll send you a new one and a label to ship back the old one. Cant' be happier with it mine now!
Celiboy
Marcel
Clovis, California
I’m going through the process of getting mine replaced now. Same problem but didn’t happen until about 6 months after buying it. Sent in pictures and a video of the problem to Tesla and just waiting for the next step.
theyoungblood
Chattanooga TN
2024 Foundation Series AWD
I've read if you are using some sort of bed mat to remove the 2 pads on the bottom of each end of the vault divider. This makes sense to me but is second hand knowledge. YMMV
Bobo_LaDouche
Carson City, Nevada
Cybertruck, Model 3
