Anyway to keep battery "topped" off?
ChiTownCT
OG Rivet Crew
Chicago
CYBERTRUCK
Currently I charge my CT to 50% for daily driving and have a schedule set to charge from 12am to 6am, so if I dont drive much during the day and charge from 46% to 50% the charging usually ends early around 4am.. So from 4am to 6am I may lose a percent or two, maybe more if sentry is on..
So if the charger is plugged in should it not keep it charged at 50%, or maybe it perhaps kicks on after a certain amount has dropped? Just not sure how it works..
Jack27
Randy
None
If I set mine to 70% I wake up and it’s at 70% so I would think it “trickle charges” so to speak to hold the percentage.
CYBERTRUCKco
Roger
Poway, CA
manufacturing
We’ve been charging ours to 80%, then drive down to 5-10% before charging. Why 50% idle I can ask?
Calendar degradation is significantly reduced below about 55% SoC. Charge higher if needed, but if you’re only using 20-30% daily then you’re better off with a lower charge point.
Also, the cells prefer a smaller DoD (depth of discharge) so it’s best to charge daily, rather than pushing it lower.
These aren’t NiCads ?
Jack27
Randy
None
Also doesn’t it say to charge 100% like one time a month ?
Jack27
Randy
None
It does not.
? I know how literal the forum peeps are so maybe I should of said “90%” it is recommended 80% to 90% for daily driving
Tesla Cybertruck Anyway to keep battery "topped" off? IMG_6570
Tesla Cybertruck Anyway to keep battery "topped" off? IMG_6571
Nowhere does this say “once a month”. LFPs are a different story.
Charging to 100% can help calibrate the BMS but is not needed for pack health, and is in fact harmful if left there for extended periods.
Jack27
Randy
None
The first photo specify the model 3
The second photo specify the CT! Like I said I know how literally ya all can be , I should have said “90%” however it does say under the CT that 100% every once in a while for optimal battery health. Here it is again. Myyyy bad I said “once a week” that is for my model 3 I never said do it all the time I said 1 time a week but again maybe 1 time every once in a while for the CT regardless it looks like not a good idea to charge constantly to only 50%.
No, it says “for optimal battery health, it's generally recommended to only charge it to 100% when absolutely necessary”.
Jack27
Randy
None
But wouldn’t you want your battery to have “optimal battery health” ?
For my “optimal mental health” I am opting-out of this conversation.
Jack27
Randy
None
? ok dude. Sorry the internet information got you so upset..
If set to charge to 50%, it generally charges to that number and shuts off. It won't start another charge cycle until it has dropped around ~3% from the set point. If you don't like that, just set it to charge to 53% and then it will start charging again when it drops to 50%.
Common sense tells us that battery data has informed Tesla that it's better if the BMS doesn't itself constantly top up the battery to the setpoint whenever it's 1% low, but to let it drift a few percent below that before topping off again.
