But How...?
Dids
Les
Massachusetts
04 Tacoma, 23 Cybertruck
Self
So a solid wall with a portal on each side to traverse the solid wall? Turn off the portal when not traversing. I wonder what the physics of that would be.
I know how to do it. I just can't tell you because it's a secret.
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
You work for Tesla too? Come on.... you can reveal to just me. I won’t tell Elon you let the secret out.
myco.rrhizae
Myco
N. Cal
F150 4.9L, Chevy Volt, Tri-Motor Cybertruck
Carpenter
seems to be the most feasible option
myco.rrhizae
Myco
N. Cal
Carpenter
depending on how much space is needed for the rolled up tonneau cover, might be able to store it in the roof above the midgate and delete the vertical tracks all together. best part is no part
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
my kid is constantly playing Minecraft and he thinks portals are a thing. My friend not worry about the portal setup is that the ender dragon or some endermen might pop out of the portal if you leave it open.
myco.rrhizae
Myco
N. Cal
Carpenter
of coarse. im sure the portal will have an auto-close function for that very reason. tesla knows what they're doing.
Deleted member 3316
Guest
Suggestions anyone...?
Cybertruck, test ride driver answers a question: where does the cover go..? Its directly behind you. The passenger was sitting in the back seat.
The best part is no part.
Make the seat back the also the pass through door.
Make the back window hinge inwards to be stored at the glass roof.
Have the rubber seals slightly pressurised with on the board compressor creating an expandable positive seal. This could make the bottom seal when the back seat/pass through door is down, waterproof.
The hinge would need some clever engineering for it to seal when either up or down but I can’t imagine it would be anywhere near as complicated as falcon wing doors.
