- Oct 3, 2020
- Western Washington, USA
Obviously, Tesla would design the way the AC charging works with peak efficiency as a top priority. Unless there is something unusual about the hardware that makes it more efficient to engage all MOSFETs, even at very low charge amperages, I would expect the highest efficiency would result from leaving the unneeded MOSFETs idle, until the requested charge current required them to be activated.I am no Tesla design engineer so this is speculative; Yes there are two parallel 24A units. I speculate/expect these to work in parallel each take a portion of the charge so _not_ one takes it up to 24A, then the other kicks in.
The failure mode supports this (when one 24 amp bank of MOSFETs fails, the charge current can still be 24 amps).
The efficiency reason is the strongest one, because obviously Tesla could build in fall-back mode for failure of one bank of MOSFETs that would then fully load the remaining good bank.
MOSFETs are not as efficient when lightly loaded. If loading all MOSFETs lightly for low amperage charging reduced charging efficiency by even 10% (it's likely a much bigger hit than that), it would be utterly foolish to design the system so they were all lightly loaded whenever charging at lower amperages.
A third possibility is the MOSFETs from bank one and two are "interleaved" when charging at low amperage. In other words, each bank is contributing to charging below 24 amps, but the individual MOSFETs in each bank are not activated until the active MOSFETs are fully (or nearly fully) loaded. But this sounds like a more complex and expensive circuit design with no clear benefit.
