Charging options?
AlmostHuman
Earth
Model X, Cybertruck
Human
Gritted Cybe
Tony
Mars
Cybertruck AWD
If you are wanting to charge at 240v with maximum charge rate this is the charger to get:
Grizzl-E Cyber Ultimate 80A
80A! That is WILD! I wonder which gauge wire it requires coming from the box. I use a nema 14-50 my father installed for his RV. Works great by my max is 32A.
cybercricket
Oregon
Depends on the type of wire (insulation rating), but likely 3AWG.
I’d recommend the Universal Wall Connector. It is the newest Wall Connector model, gives you the option to install Powershare later if you had the need.
https://shop.tesla.com/product/universal-wall-connector?sku=1734411-02-E
If you think you want Powershare at some point you could pick up the bundle.
Powershare Home Backup Bundle
https://shop.tesla.com/product/powershare-home-backup?sku=1841000-99-B
Preemptively buying a Powershare kit seems extreme though. Especially since it's redundant to Powerwalls.
Check local regs. Homeowners in some states (like mine) are legally not allowed to do their own electrical work.
I don't know any state that bans this, only municipalities. And it's stupid. Electrical work is pretty simple, and has rules.
But if you do it wrong it will catch fire.
JCERRN
J
Around
Yeah
Massachusetts.
JCERRN
J
Around
Yeah
Though i do agree. Follow the rules and it should be fine.
Reactions: REM
Nidavellir
AWD CyberTruck
No Tesla currently sold has a charger that draws more than 48A, which a Wall Connector supplies when on a 60A circuit.
Level 2 chargers typically offer a range of amperage, a Cybertruck can potentially charge at 80 amps if equipped with a suitable charger and a 100-amp dedicated circuit.
Here's a more detailed explanation:
  • Level 2 Charging:
    Level 2 chargers are designed to deliver faster charging speeds than Level 1 chargers, and they can vary in amperage output, ranging from 15 to 80 amps.
  • Cybertruck Charging Capacity:
    The Cybertruck is designed to accept charging at a maximum of 80 amps, but it depends on the charger and the available circuit.
  • Required Infrastructure:
    To achieve 80 amps of charging, you'll need a Level 2 charger capable of delivering that amperage and a dedicated 100-amp circuit breaker installed at your home or location.
AlmostHuman
Earth
Model X, Cybertruck
Human
Oh I didn‘t see the OP say they had Powerwalls.
