CT won’t lock and sleep after exit….
ErickW
Erick
Reno
Project Manager
Does anyone have issues with the vehicle not locking and going to sleep after you walk away? This has haunted me for the last 6+ months. They had a bug fix, then the next update broke it again. I’m curious if anyone has experienced this same issue and if their dealer fixed the issue permanently.
UberNoob
CyberBeast & M3P
Desktop Security Engineer
I don’t have the issue u till I leave my phone behind, close the Tesla app, or disable Bluetooth then it happens every time.
Chesapeake Beach, MD
'23 MYLR, FS Cyberbeast 280xx
No. I'm on Android. I know there are phone settings to connect to vehicle and if you have Bluetooth set to disconnect from vehicle before you step away, the CT won't know you left. It'd be neat if the cameras recognized you upon approach but, alas... Not an issue at work here but at another place, I can't even take my phone into the building so it'll have to be left behind (and disconnected).
Perhaps some innocuous setting on your phone is causing the issue.
JCERRN
J
Around
Yeah
you may have walked away door lock disabled… You can try resetting your phone key, you could also try pairing and un pairing your phone, trying a different device, and make sure you go to your settings Doors/locks and check that walk away door lock is enabled.
ErickW
Erick
Reno
Project Manager
Thank you, I appreciate your suggestions. I have tried all of these items. Each time there is an update.
If I have a passenger, the vehicle will act as designed when they depart the vehicle. This issue is clearly tied to the driver's door.
Just get out on the passenger side 🤷‍♂️
RickBush
Rick
Olympia, WA
3,y,x
Bussinessman
When a seatbelt was left connected. Dog seat
CapheDa
Dustin
Brea, California
2018 M3, 2023 M3P, 2024 CTFS
Investor
I had this problem and tried everything except opening a ticket. Still had the problem. Then one day the problem was gone. Walk away door lock worked suddenly and never had the problem again. No idea what solved it. The problem lasted about 3 days and this was about 2 weeks ago. Just fyi. Probably not helpful…
Araknai
Alex
Minneapolis
Cybertruck AWD Dual Motor
Electrical Engineer
I'm experiencing this exactly the same. It was fixed and came back. Now if the driver's door is not the one that was most recently closed it won't sleep when I walk away.
jeniferkey
Jennifer
Fort Worth, TX
Cybertruck and Model 3
Mine will do this if I leave the passenger seat belt connected. I had to use the app to lock. I guess it thinks your passenger hasn’t left the vehicle.
ErickW
Erick
Reno
Project Manager
Mine is the opposite, if the driver's door is only used, it will not lock.
ErickW
Erick
Reno
Project Manager
This is a great point. I have all my seatbelts connected. I put backpacks or other items on the seats. To prevent the pop up, o buckle the belt.
Thanks for the note; I’ll see what Tesla comes up with today and try this if they do not figure it out.
Tesla Pilot
Henderson NV
2024 Cybertruck (Non Foundation Series) & 2024 Model S
I had the same problem after a software update and found out that the update somehow signed me out of my Tesla account, so I logged back in, did a reboot (which probably wasn't needed) and that fixed the problem.
JackCypher
Cybertruck Foundation
CEO
I am also on android, samsung. I have not had that issue, I do have in the last 2 software updates, a long delay 1 in 3 times unlocking the CT with phone in my driveway.
