Cybercarlson
- T.C.
- Jun 3, 2020
- Germany
- chevy K1500 decades ago, M3, MY, New Beetle
Think futher..... Robotaxi for Cargo.....
Sorry to say that you are probably wrong and that you don't understand how it worksExact moment that Elon confirms 1000V Architecture / V4 Supercharging for Cybertruck too
The Supercharger operates at the same voltage as the battery current voltage. (or little higher to regulate the amp)Megacharger is just a v4 Supercharger. V4 Supercharger can operate at 500v or 1000v. If it’s only operating at 500v, it has half the charging speed. Any Tesla can use the v4 charger…
Every single Tesla can use the v4 charger. The only special sauce here that the Cybertruck can have in common with the semi is unlocking the full capacity which requires 1000v charging. I don’t see how they could mean anything other than that the Cybertruck.
It is far more likely they ship it with 1000v than hit 1000 kW charge speed.
Or CT could do what porche taycan does and split strings for lower voltage chargers.Sorry to say that you are probably wrong and that you don't understand how it works
Elon confirmed that Cybertruck will use V4 Supercharging but NOT that Cybertruck have 1000V Architecture.
If Cybertruck would have 1000V Architecture it will not be able to charge att V3 Supercharger because they deliver max 400V, so Cybertruck have most likely 400V Architecture.
V3 Supercharger can deliver 250kW at 400V, thats 625A.
V4 Supercharger can deliver +1000kW at 1000V, thats +1000A
If Cybertruck or SX3Y charge at V4 Supercharger, than it gets max +1000A or 400kW at 400V.
Please see Munro video about 4680 cell evolution. They claim that latest 4680 cells used in Model Y are different than earlier ones. They called them semi solid state cells.
A solid state lithium cell could have a much higher cell voltage....
It could have very low internal resistance...
Elon said CT gets 1MW charging. They never said CT would have 1kV architecture but it would be outside NACS specs to do 1 MW charging @ 500v.
Besides if they are making 1kV invertors for Semi than using same part for CT makes sense.
I disagreeThese are just random high charge rate batteries. I'm not saying that cybertruck will do 1mw continously. But it probably will up to 75% or so, we just don't know enough and have to go on what they say.
To reiterate...
Cybertruck will have 1MW charging -Elon
V4 supercharger is 1MW. - charger cable slide
NACS is the plug for V4 - NACS spec sheet
People can disagree but this is what they said....
I've moved into Taj-Ma-Haul (20' Toy Hauler Luxury Conversion) full-time and I'll be criss-crossing the US to spend time with my aging mother and my kids going to college.That seems like a rather unusually busy day that they loaded, drove a few hundred miles, unloaded, then came back to do it all again.
Most delivery trucks don't do that sort of mileage.
Update: 1000V architecture / V4 supercharging for Cybertruck was confirmed during the semi live event!
Posted by @firsttruck:
Here is link to Tesla Semi Delivery Event but the video is cued to start at info on SuperCharger V4 MegaCharger and also Cybertruck charging.
2020 Dec 1
Exact moment that Elon confirms 1000V Architecture / V4 Supercharging for Cybertruck too:
I'll be watching what you'll be doing although we've not full timers.I've moved into Taj-Ma-Haul (20' Toy Hauler Luxury Conversion) full-time and I'll be criss-crossing the US to spend time with my aging mother and my kids going to college.
I mentioned before, Taj-Ma-Haul will be outfitted with 8 x 14kWatt/hr batteries for 112kWatt/hrs of storage to help charge the CT. It would be nice to "dump" all of that stored energy as quickly as possible into the CT to expedite moving about. It would also be excellent if I could connect the 2 together for bilateral charge/discharge even in transit.
My current inverter can handle 120amps, sure would be nice to use as much of that as possible.
I know I'm the exception, but there are use cases out there.
Good points.At $400 for the Wall Connector and $230 for the Mobile Connector and another $100 for an industrial grade NEMA 14-50 outlet the difference for the superior solution is only $70. If the install is 50 feet from the panel you will pay that much just for the extra conductor that the outlet requires bringing the total cost to parity.
Even if the Wall Connector costs a few bucks more it's worth it for the thicker, more durable 24 foot cable, more power and fewer potential points of failure. It's just more robust and satisfying to use and has built-in cable management. There is also the option to piggyback one or more additional Wall Connectors on the same breaker so you can do intelligent load sharing with two or more EV's.
Before I knew better I thought the Mobile Connector would be a lot cheaper but it turns out it's basically a wash once all is considered. Using a NEMA 14-50 as a placeholder for a future Wall Connector is not a great idea and would end up costing even more in the end.
"It" that Elon is referring to is a pronoun. The noun is clearly Surströmming.I disagree
All Elon said was "It's gonna be used for Cybertruck too"
Nothing more.
But it is up to you to interpret as you wish
Göran is absolutely right! That verbatim quote by Elon followed many possible topics as to what "It" could be referring to:I disagree
Nothing more.
My fact free take is based on CONTEXT: Large build up to announce the Semi's ability to charge using in the new 1000v architecture proceeded by a dramatic pause and then let the king himself announce that the CT will also use it too.At one end of possible conclusion to be drawn is merely that the CyberTruck will be able to plug into a V4 SuperCharger. At the other extreme of possibilities is that the CyberTruck will be able to charge at a MegaWatt rate!!!
I am 100% certain that the former is true, but am willing to bet a dozen shares of $TSLA that the latter ISN'T true.
