Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH
TeslaKen
Ken
Overland Park
www.halocybertruck.com
Currently Occupied
I finally received my adapter today that I ordered a few months ago. Evidently there was an issue in the initial batch and they had to be redone. I thought I'd share some pictures. It comes in a nice case and feels solid in hand, plenty of heft to it. I have not tried it yet, but as soon as I do I will report back here what the results are. Until then, enjoy the pictures!
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH 20241028_201134
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH 20241028_201113
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH 20241028_201053
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH 20241028_201121
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH 20241028_201104
tcmeyers
Troy
Washington State
2024 Cybertruck Foundation AWD, 2018 Tesla Model X 100D
Botanist
I have a feeling there are a number of these with various branding all showing up right now. Here are pics of mine, including one to compare with the length of the Tesla one that doesn’t fit the Cybertruck. I will test at a CCS1 charger tomorrow.
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0565
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0564
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0566
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0567
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0568
TeslaKen
TeslaKen
Ken
Overland Park
Currently Occupied
Indeed looks like the same one I received just from a different company and as you said they all seem to be sourcing from the same supplier, box is the same, etc. Let me know how it works as I don't know if I will have time to test tomorrow or not yet.
tcmeyers
Troy
Washington State
Botanist
Indeed looks like the same one I received just from a different supplier and as you said they all seem to be sourcing from the same supplier, box is the same, etc. Let me know how it works as I don't know if I will have time to test tomorrow or not yet.
Will do! ??
CT425
WA
Cybertruck AWD Foundation
Thanks in advance for your reports! I and many other CT owners will need one.
cardad
Kelvin
Moab
R1S, R1T, Bronco Raptor
I got that one too from EVBase. Let’s hope it works ?
tcmeyers
Troy
Washington State
Botanist
Here is the link for the EVBase one:
EVBase CCS1 CT adapter
I just tested it, and it seems good… I had a good battery and was charging from 70% to 80% just as a test. This was a EVCS charger at a local grocery store. I put the big hose into adapter, and plugged that into the truck. Then I activated the charger (QR code shown to the EVCS app) and it didn’t work the first time so I shoved it in harder and tried again. Then it worked.
The charge rate was pretty low to begin with, 40kW but it gradually got up to 63kW. Probably because of the cold battery, but at one point the CT display said “charge rate limited by charging station” though I was to only vehicle there. So, it worked OK.
The one difficulty is that plugging the hose onto the adapter was hard, I had to push down on the ground. Worse was unplugging it, I had to wrestle with it. I wish the adapter had a better surface for gripping, and it ended up flying off and falling on the pavement. I didn’t seem damaged..
Oh, the adapter seemed to rest on one spot of the CT’s port exterior, so it was a little better than just the tiny NACS snout holding it up.
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0596
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0583
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0597
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0579
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0580
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0586
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0595
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0591
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0581
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0585
The one difficulty is that plugging the hose onto the adapter was hard, I had to push down on the ground. Worse was unplugging it, I had to wrestle with it. I wish the adapter had a better surface for gripping, and it ended up flying off and falling on the pavement. I didn’t seem damaged. I might take a tube of silicone grease and put it on the hose end first.
Please do not apply any substances no matter how benign seeming to charging equipment surfaces that are, or interface with, ones that are publicly used.
cardad
Kelvin
Moab
I couldn’t get my EVBase adapter to work at a chargepoint that I’ve used plenty of times. It slid right on and I pushed it in as far as it would go. The adapter touches the fender so there’s no way it can go in any further.
After multiple attempts to start. a charge I gave up. I don’t think this is ready for prime time as I would have been stuck if I had relied on it with the route that has no supercharging.
The station was waiting for the vehicle and the error message seemed to indicate that the plug wasn’t seated all the way in but there was no room to go further.
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0204
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0202
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH IMG_0201
I'm guessing you've had that adapter a while?
Cybertruck from same company one is new and longer.
Tesla Cybertruck Cybertruck CCS1 x J1772 to Tesla(NACS) Fast Charging Adapter by TESLAUNCH SmartSelect_20241031_081839_Firefox
cardad
Kelvin
Moab
No this is the new CT version. I don’t own any other Teslas.
Oops, my bad.
I miss read the "used many times" as the adapter and the Chargepoint station.
And I see your photo matches the new design.
That's weird it doesn't fit. Maybe it was pulled at a downward angle? Top finger was making contact?
