CTSoFL
South Florida
On State Certified Scales for Little Rock Solid Waste Disposal. 7120 lbs ~ 3236 kg.
Full or empty tank of gas?
It makes a difference you know.
Also, charging the battery adds the weight of those electrons.
Tesla Cybertruck Cybertruck (Cyberbeast) Weight on Scale: 7120 lbs (~3236 kg) d3mlE7uhX8KFgEmY
JoshSchrock
Josh
Missouri
Cybertruck Beast
Home Builder - Real Estate
Which is heavier, a 7,120lb Cyberbeast or 7,120lbs of feathers?
rudedawg78
Ernie
South Carolina
Quite significant too:
"The electron actually weighs 9.11x10-28 grams. This means it would take about 1,830 electrons to equal the mass of one proton."
DrPhyzx
Santa Cruz Mountains
Bolt EV, Ariel Atom
particle physicist
Haha... except that charging the battery doesn't "add electrons" so much as it rearranges the charges in the battery from one with low potential energy to an arrangement with higher potential energy, like pumping water from a lower reservoir to a higher reservoir, so the process can be reversed later to do work.
That said, a charged truck does very literally have larger mass than a discharged one via E=mc^2, where 123 kW-hr is about 5 micrograms. Such is the power of nuclear energy: a gram of mass is equivalent to the energy needed to charge 200,000 cybertrucks.
rudedawg78
Ernie
South Carolina
lol, you got me! I definitely am not doubting a Particle Physicist! ;)
Tinker71
Ray
Utah
Project Manager
So how do weights compare be against other CT. Are they installing different batteries?
mhaze
mhike
Tesla 3; Smartcar; F150 Raptor; Avalanche 2500 4x4
Tinker71
Ray
Utah
Project Manager
All Cybertrucks have 4680 batteries made in Texas.
At some point gen 3 batteries will be installed. I am anxious to see if the weight changes and if they will software limit etc.
