Cybertruck ready for serious off-roading!
azjohn
john
Henry County Virginia
Toyota Tundra
Mounting and powering a winch is one of my questions as while. The truck also needs bumper hooks. I will definitely be using my CT as a toy hauler to take my Jeep to Moab and will probably wheel both. Jeeps plugin Wrangler is a stepping stone and they will eventually come out with a BEV Wrangler. I am hoping for a 4 motor version with the suspension of the Cybertruck.
No offense but you are dreaming about the Jeep with 4 motors, its a plug in hybrid with a 16 KWH pack
Sgt. Glenn
Scott
Utah
www.cybertruckphotography.com
2012 JKU Call of Duty/ Modern Warfare Edition
Aerospace Photographer
I am not talking about the hybrid. I have knowledge of their next Wrangler just not the specifics. They will be announcing an all electric Wrangler in a couple years.
FullyGrounded
blah
blah
I plan to overland as well, though, my overlanding will also be ready for a road that has rockslid into limited existence, as well as other eventualities that happen in the real world, off the beaten path. I will be traveling everywhere where it's recommended, and some places that aren't advised. Me and my golden retriever, Bam Bam.
One note on bead locks: They are non-compliant with DOT rules, so offered as Off Road only. Sad. Kind of hard to make a full-on Zombie Apocalypse Vehicle without bead locks... or air down properly, in all situations without bead locks. peace
ldjessee
Lloyd
Indiana, USA
I have never seen a truck pulled over for beadlocks... or heard about an insurance claim be denied because of them...
FullyGrounded
blah
blah
Yeah, I haven't been looking for people pulled over for having them, nor checking all insurance claims. I tend to do other things for fun. peace
azjohn
john
Toyota Tundra
trucks are normally sold as beadlock capable to remove the liability. I have had non bead lock tires that I have air downed that were fine. I wouldn't worry about bead lock unless you got to the area of 10 lbs psi which I feel is unnecessary
ldjessee
Lloyd
Indiana, USA
Having rolled a tire from the rim/wheel on the street, if I was the kind to do high speed or very hard rock crawling, I would probably plan on getting beadlockers...
But I plan more on the overlanding style of offroading, so will probably never bother with beadlockers on the CyberTruck.
slomobile
Dustin
Memphis
Roboticist
Other Teslas have an open diff, which I think has an e-diff function of braking the slipping wheel to transfer torque to the other side. This wouldn’t be ideal for off-road where wheels often get lifted in the air and have no traction. In that case the brake would have to overcome the full torque of the motor in order to drive the opposite wheel, which would be really rough on the brakes. I’m hoping the CT has either a locking mode or one of the newer clutch pack systems for sending torque side to side.
Braking a spinning wheel with no traction is not difficult or hard on the brake. It is easier than any normal traction braking which must convert the momentum of the entire vehicle to heat, rather than just the momentum of a single unloaded wheel. A clutch operates with friction in the same manner as a brake. Brake or clutch, the effect, and the wear are about the same. Brakes have the advantage because they are further outboard and the stopping force need not be carried through shafts, splines, and joints which can wind up or break.
Wear on a clutch is significantly lower, being that it's enclosed and wet and not meant to grind tons of momentum to a halt.
Huh?
Zabhawkin
New Mexico
The current Jeep Rubicon does the brakes when the differentials are not locked and it is quite effective. The Rubicon can lock the differentials completely as well.
She is talking about the standard limited slip differential, they use clutches to transfer power to the wheel with grip. They honestly don't do that well long term in more extreme off roading.
A common self locking differential uses oil viscosity to transfer torque, not clutch plates, many manually locking ones just stop the planetary ring from spinning to put equal torque on both wheels.
But that is not the reason for my comment.
Brakes convert momentum into heat and do so very effectively and repeatedly. If your brakes are "grinding" you to a halt its well time to get new pads. 🙂
