LuvOrH8
San Diego, CA
Cyber Truck
So I bought the Lift Rod kit, at only $80 for the full set of 4 it was an easy decision. Why? I don’t like how the front nose sits lower than the rear end of the truck. It may be for aerodynamics, but I don’t care. I wanted it higher in the front. With that I didn’t install the rear pair, and did the front only. The results speak for themselves. In entry/low mode as shown in the photo it now sits basically level. Install was super easy, took seriously 2 minutes per side.
According to @CYBERTRUCKco at stock height, the front sits in low mode at 37.125” and the rear at 37.825”. With this kit installed in the front only, the front end now sits 1” taller at 38.125” making it just slightly higher than the stock rear height. Exactly what I was looking for. I did this for aesthetics only and this was a quick and easy solution. Highly recommend if you want the same look.
Here’s link to buy: https://cybertruckco.com/product/cybertruckco-lift-rod-kit-raises-truck-625-2-height-over-stock/
Tesla Cybertruck CybertruckCo Lift Rod Kit - Front Install Only Result cybertruckco lift rod kit front install only
Tesla Cybertruck CybertruckCo Lift Rod Kit - Front Install Only Result IMG_0360
Gaximus
Mead, CO
Software Developer
It’s a bad look. Level looks good, front a little lower is slightly worse, but front higher is the worse possible look. It’ll also ruin your headlight aiming. You’ll be blinding everyone with just your low beams.
Cybertruck Dude
Illinois
OperatingEngineer
It’s a cyber truck of course it looks good! Cyber Trucks always look good! No matter how you rake it! At the end of the day, If it makes you happy, you do you! ?
Wolfgram
Joseph
Model 3 Performance
CTO
Thanks for sharing! I plan to raise mine with these parts… but I’ll do front and back. Did you notice any difference in comfort/bump harshness or handling?
Cyberus
When I saw this, I knew it was someone in Southern California. ?
Anyone who doesn’t live here, wouldn’t understand.
I do think we’re going to get an update that will allow adjustments to the ride height independently front and rear. The nose does tend to dive at times when it should raise.
Pops
Houston, TX
MY, CyberBeast
Anyone can adjust the position of the headlights in the service menu, its a pretty nice feature.
Honestly it looks fine to me, but I do not even notice the difference. Maybe if I saw it side by side with stock CT I would notice it.
Wolfgram
Joseph
Model 3 Performance
CTO
I lived in SoCal for a number of years… but I don’t get it. Why is a level truck important?
Gaximus
Mead, CO
Software Developer
I level truck is symmetry. And 4x4 trucks usually come level, 2x4 typically sit higher in the rear factory. But this mod isn’t level. It’s nose up. Which gives it that “broken rear suspension “ look, that some prefer.
Wolfgram
Joseph
Model 3 Performance
CTO
Ahhh… a slight Carolina Squat. I thought the same thing. I’m not a fan myself, but I can see how some might like that.
Freemarket
Southwest
Stay at home Daddy
I was not much of a fan with the fronts only so I did all 4 wheels. I am loving the extra height in Med high. Makes a big difference for me on road. Here’s a pic of the front only on my rig.
Tesla Cybertruck CybertruckCo Lift Rod Kit - Front Install Only Result IMG_1278
RVAC
Looks like they need to make a set of lift rods that aren't quite as tall just for the front as this kit raises it too high.
Dantes
Manhattan Beach
Beat me to it. Was gonna say exactly this. It does warn you that it should be done by a trained technician only but its so simple to do. Especially if aimed at a wall to make sure both left and right lights are at the same level.
Freemarket
Southwest
Stay at home Daddy
The photo I posted that you commented on, only had the lift bars in the front, that’s why the front appeared higher than the rear, it was.
RVAC
I know, the point I'm making is they should sell a set of fronts that is a bit shorter for those that are looking to level the truck (i.e. neutralize the factory positive rake angle).
