Tonneau cover stuck
Kevin Burns
Kevin
Model S P100D, Model 3 LongRange, CyberTruck all-wheel drive
My tonneau cover is stuck. It seems to be cocked at an angle. It won’t move forward or backward.
That Beast Mode
Phil
New Jersey
Easy fix
Tesla Cybertruck Tonneau cover stuck 2_c05d8018-6c58-4e5a-82ff-d3987fc20d2f_480x480.jpg
There is some calibration method in the service menu, I don't know if it'll work being its completely jammed up, but nothing to lose at this point, you're looking at a service appt either way.
Kevin Burns
Kevin Burns
Kevin
I was able to get my tonneau cover to work again. I noticed that, when nearly closed, it was a bit ascew. I pressed on the open button and banged on the end of the tonneau cover with the base of my hand. It moved a little, I kept pressing on the open button, banging on the outer edge with the heel of the palm of my hand and it rolled up completely. I tried to roll it back out by pressing the close button and it wouldn’t budge. So, I got in the cabin, found the calibration control on the main screen and did a calibration, but it didn’t budge. I did a computer reset by holding down the 2 scroll buttons on the steering wheel. Still wouldn’t budge.
Somehow, I got it to work from the control screen. It must have been the reboot.
That Beast Mode
Phil
New Jersey
At least it works, I'd still probably make a service appt since you won't get one for a month anyway. im sure something is out of alignment. Did you do the calibration in the service menu? Might be different than the one you did, worth a look.
Freeseframe
Iowa
2024 Cybertruck AWD; 2019 Model X; 2017 F150 SuperCrew
If the tonneau is still crooked, get the appointment set up. Mine developed that over time and got to the point it would need recalibrating every week since it wouldn't fully close without holding the button. Service Center replaced the rail assembly (essentially the track the rollers roll on) and has been perfect ever since. Mine is an April 2024 build and evidently the rails had gotten updated due to what they said was binding problems they saw in the field.
BengalBoy
Alabama
Attorney
Mine did this today. Would only roll back 6 inches at each button "press" which I did until it went all the way back and down to "stop." (I thought it would re-seat properly once rolled completely down.) Would not come back up. I can hear the motor click when I let it cool down, but, can't get it to come back up. I took delivery in April, 2024. "Binding Problem" is exactly what I have experienced. I made a service appointment and after reading your experience believe I am having the same issue. First issue with my CyberTruck since I took delivery.
