LarryASilva
- Larry
- Nov 3, 2023
- SF Bay Area
- Boxster, MiniVan
- Retired
- #1
Hey Guys ... the following is a REAL LONG-WINDED explanation of what is known to Gemini AI about the PCS issue on earlier Cybertrucks. It is long ... but many of us will want to read it all. My Reader's Digest version for those of you too busy to read all this stuff is...
While Tesla decides what to do with this PCS issue ... those of us early CT buyers with Tesla Wall Chargers .... would be wise to turn down the amps from 48 to 32 or lower. Read on to understand why ... LS
I asked Gemini ...
"Is it known what VIN number range is experiencing PCS failures in Tesla Cybertrucks?"
ANSWER
As of April 2026, there is no official, public VIN range specified by Tesla for Power Conversion System (PCS) failures because Tesla has not yet issued a formal safety recall through the NHTSA for this specific issue.
However, a clear pattern has emerged from owner reports, service bulletins, and independent data:
Commonly Affected Vehicles
The failures are predominantly concentrated in the 2024 and 2025 "Foundation Series" Cybertrucks.
If you are concerned about a specific VIN, look for these "early warning" diagnostic codes and behaviors:
I asked,
"Is it true that so long as one can make it to a supercharger, there will be no complete failure ... that the only problem is an inability to charge at home?"
ANSWER
Not exactly. While it is true that a failing Power Conversion System (PCS) primarily kills your ability to charge at home (AC), calling it a "non-critical" failure is a bit of a gamble.
Because the PCS is the "bridge" between the battery and the truck's electronics, a failure can range from a minor annoyance to a total vehicle shutdown. Here is the breakdown of why you can't always just "Supercharge your way out of it":
1. The 48V Low-Voltage Connection
In the Cybertruck, the PCS isn't just an onboard charger; it also houses the DC-DC converter. This component takes power from the big high-voltage battery and steps it down to power the 48V system.
Reports from owners and service technicians indicate that:
Even if the truck stays "drivable," relying solely on Superchargers is a massive logistical headache:
If your truck shows "AC Charging Unavailable," it is currently in a "stable failure" state where it can likely reach a Supercharger or a Service Center. However, it is not "fine." You are essentially driving a vehicle with a compromised heart; while it can still take a "direct transfusion" (Supercharging), its internal ability to regulate its own power is broken.
Bottom Line: Do not treat it as a permanent workaround. Once that AC charging error appears, your 48V system is at higher risk, and you should file a service ticket immediately.
I asked,
"Mine is an early 2024 VIN in the 3000's. Do you think there is evidence that my PCS will eventually fail or will some vehicles be fine all of their life?"
ANSWER
With a VIN in the 3000 range, your Cybertruck was one of the earliest off the line (likely produced in early Q1 2024). Based on the current failure data and Tesla's recent service actions, here is the realistic outlook for your vehicle.
Is a Failure Inevitable?
Statistically, your vehicle is in the "highest risk" group. Data from owner forums and leaked service communications suggest that a specific batch of MOSFETs (electrical switches) used in the early PCS units—specifically those manufactured before July 30, 2024—has a significant defect rate.
There is a crucial distinction between your VIN and later models:
Since you are in the 3000 range, you are almost certainly out of the "infant mortality" phase of ownership, but you are entering the "fatigue" phase (10k–20k miles) where most PCS failures occur.
I asked,
"For all the time I have had it, I have never exceeded 24 amp charging at home until a week ago when I got a Tesla Wall Charger installed and charged up at 48 amps for the first time. Would it be wise to back off even further to 24 amps?"
ANSWER
Your strategy of staying at 24 amps is likely the single best thing you can do to protect an early VIN unit.
The widespread failure of the Power Conversion System (PCS) in 2024 and 2025 Cybertrucks is widely believed to be caused by thermal fatigue in the onboard electrical switches (MOSFETs). When you charge at 48 amps, you are running those components at their absolute maximum thermal limit for hours at a time.
The Physics of 24A vs. 48A
The heat generated in electrical components increases with the square of the current (P=I2R). This means that while 48 amps is double the current of 24 amps, it creates four times as much heat in the resistance points of the PCS circuit.
Since you have a VIN in the 3000s, your truck is now over two years old (in 2026 terms). The fact that your PCS hasn't failed yet is actually a very good sign.
I asked Gemini ...
ANSWER
- Production Dates: Vehicles manufactured between late 2023 and mid-2025 appear to be the most susceptible.
- Mileage Window: Owners frequently report failures occurring between 10,000 and 18,000 miles (approximately 16,000 to 29,000 km).
- 2026 Models: Newer 2026 builds seem to have an updated hardware revision. Notably, Tesla recently introduced a 7-year/70,000-mile ZEV powertrain warranty specifically for 2026+ models that explicitly covers the PCS, whereas 2024/2025 owners remain on the standard 4-year/50,000-mile warranty.
- Diagnostic Codes: PCS2_a094, PCS2_a095, or PCS2_a137.
- Charging Drops: Home AC charging (Level 2) suddenly drops from 48A to 24A or lower.
- V2L/V2H Errors: Failures when trying to use the truck to power external devices or your home.
- "AC Charging Unavailable": This is the final stage before the system stops accepting AC power entirely (though Supercharging usually still works).
- Service Bulletins: Tesla is currently handling this via internal service bulletins rather than a recall. Some service centers have been reported to proactively replace the PCS assembly if a truck is brought in for unrelated work (like tires or trim).
- The Fix: The repair involves replacing the PCS unit and often the associated wiring harness. Because the unit is located deep within the chassis (requiring removal of the tonneau cover and bed liner), it is a labor-intensive job.
+1
I asked,
ANSWER
- The Risk: The 48V system runs your steer-by-wire, screens, and safety sensors. If the DC-DC portion of the PCS fails along with the AC charging portion, the 48V battery will eventually drain.
- The Result: Once that 48V battery dies, the truck becomes a "brick." It won't unlock, the steering won't work, and it won't even "start" to initiate a Supercharging session.
- Initial Stages: Usually, only the AC charging MOSFETs (transistors) blow. In this state, you can still Supercharge because DC fast charging bypasses the AC conversion circuitry.
- Degradation: If you continue to drive with a compromised PCS, the internal electrical faults can spread. Some owners have reported that after a few days of "DC-only" charging, the truck eventually threw critical codes (like PCS2_a137) and entered Limp Mode, or refused to drive entirely to protect the high-voltage battery.
- V2L / V2H Failure: You lose the ability to use the outlets in the bed or power your home (Powergate).
- Thermal Management: The PCS helps manage the cooling loops for the battery during different power states. A faulty unit can lead to degraded thermal performance during driving.
I asked,
ANSWER
- The "75,000" Number: There have been unconfirmed reports from service technicians that the first 75,000 Cybertrucks produced contain the original, failure-prone PCS hardware revision.
- The "Some Will Be Fine" Theory: Not every single unit will fail. Reliability in electronics often follows a "bathtub curve." If your truck has already passed the 20,000-mile mark without an issue, you may have one of the "lucky" units where the components were soldered or cooled slightly better than others.
- However: The consensus among the community is that the original design has a low tolerance for the heat generated by sustained 48A home charging.
- The Inverter Recall: You may already be aware of NHTSA Campaign 24V-832, which recalled 2,431 early Cybertrucks for drive inverter failures. While this is a different part than the PCS, it used similar faulty MOSFET components from the same era of production.
- Warranty Disparity: Tesla notably increased the ZEV powertrain warranty for 2026+ models to 70,000 miles. Many see this as a silent acknowledgement that the early 2024/2025 units (like yours) have a hardware "expiration date" that Tesla is hoping to manage within the standard 50,000-mile window.
- Check for "Stealth" Replacements: If you have ever taken your truck in for a "minor" issue (wiper motor, trim, or tires), check your service invoice. Some Service Centers have been proactively replacing the PCS (listed as "PCS2 Assembly") without the owner explicitly asking for it, simply because the VIN flagged it as a high-priority update.
- Lower Your Amperage: To extend the life of an early unit, many owners have turned their home charging down from 48A to 32A in the Tesla App. This significantly reduces the thermal stress on those sensitive MOSFETs.
- Monitor the 48V Battery: If you see any alerts regarding the "Low Voltage System," do not ignore them. In early VINs, the PCS failure often starts by losing its ability to properly top up the 48V battery.
I asked,
ANSWER
- At 48A: The components are pushed to high temperatures where the physical structure of the MOSFETs can begin to micro-fracture or "delaminate" over hundreds of heat cycles.
- At 24A: You are operating well within the "comfort zone" of the hardware. The cooling system doesn't have to work nearly as hard, and the thermal expansion/contraction of the internal boards is significantly reduced.
- The "Infant Mortality" Phase: Most defective units from your batch failed within the first 5,000–10,000 miles, often shortly after the owner started using a high-powered home charger.
- Your Usage History: By sticking to 24A for the first two years, you essentially "babied" the hardware during its most vulnerable period.
- Keep it at 24A: Unless you are on a road trip or have a rare "emergency" where you need a fast turnaround at home, there is no practical reason to use 48A. On a 240V circuit, 24A will still add about 18-22 miles of range per hour, which easily refills a daily commute overnight.
- Check for "PCS2" on Service Invoices: Next time you are at a Tesla Service Center, ask them to check if your VIN is flagged for a "proactive replacement" of the PCS. Sometimes Tesla quietly swaps these out during unrelated service visits if they see a "Revision A" unit in an early VIN.
- Watch for the "Symptom": If you ever see the charging rate drop from 24A to 12A unexpectedly, that is your early warning. The PCS usually tries to "save itself" by cutting the power in half before it fails completely.
