Fix Yellow foam under front windshield?
ravedoc
Marc
LA
Have Cyberbeast foundation and yellow foam under front windshield visible on both corners.
Per Tesla Van Nuys, CA service center "Repair notes: No replacement needed. Confirmed with other Cybertrucks on site this is normal fitment. As well as confirmed with management. If new one was replaced dash will look the same."
Do others see this foam and have fix? Possibly black fabric over but will this block window defroster?
Thank you for help.
Tesla Cybertruck Fix Yellow foam under front windshield? IMG_7464
Tesla Cybertruck Fix Yellow foam under front windshield? IMG_7465
Tesla Cybertruck Fix Yellow foam under front windshield? IMG_7468
Tesla Cybertruck Fix Yellow foam under front windshield? IMG_7481
Pops
Houston, TX
MY, CyberBeast
That really sucks, here is your $3 fix. I believe what you are seeing is a reflection, its below the dashboard line.
Tesla Cybertruck Fix Yellow foam under front windshield? 1733602964652-br
yohst
yohst
I have a CBF and don’t see that foam. Seems SC is making it a bit easy on themselves?
Well, if it's just right in the over flow area, it would be hard for them to do and not have it show.
Some things are easier to do right than repair, and then just.., look odd. That should be UV resistant foam that's black, if it's near the edge, but you know Tesla.
igs
CT, MX, MY
It's a reflection and visible only under certain lighting conditions.
Drano
Wayne
Naples FL
Cybertruck; MYP; C8 Corvette
Thank you for help.
Haha. I thought it was leaves from one of my trees!! So I opened the fronk and they were gone. must be certain lighting. But I do see also
Art138
Art
Weston,Florida
MYP,Ford GT & FS CYBERBEAST
My dash material on my FS Beast appears different….could be resolusion of photograph. Anyway,I checked mine closely and the material abutts the glass with no gaps. If it’s not leaves on the other side of the windshield the windshield installer left adhesive slopply. Not the easiest part of the end dash to get to. You may be able to scrape some off with a long handled screw driver. As usual, the SC is full of BS. Yours should look like mine.
Tesla Cybertruck Fix Yellow foam under front windshield? IMG_2099
JUSTICEQD
Benjamin
Johns Creek, GA
Doer of IT stuff
Had the tint shop correct whilst installing. Think they just cut it back
dalton108
Dalton
Lawyer
Same I noticed it at delivery and I thought it was a leaf or something as well. And then I realized it was on both sides. I haven’t dealt with it in any way just coping. It’s only under certain lighting conditions.
