- Oct 3, 2020
- Western Washington, USA
I think you will find that the OEM Cybertruck All-Terrain tires will not be more prone to sidewall cuts than a traditional non-energy saving all-terrain tire because a stiffer sidewall is also good for low rolling resistance. And you will notice that these tires have very little sidewall bulge, that is what makes many tires vulnerable to sidewall cuts. All-terrain tires are reinforced against sidewall damage and the OEM Cybertruck tires are no exception.Especially with the OEM tires as they are a very dumbed down AT tire to try and maximize range.
Most sidewall cuts can be avoided by having good driver skills. A good off-road driver picks better lines, and good lines rarely cause sidewall cuts (when combined with appropriate tires and pressures). Also, people rarely understand appropriate pressures to use in different off-road situations. Keeping the tires reasonably aired up for rocky terrain will help prevent sidewall damage which is all too often induced by poor driving and poorly setting tire pressures to match the conditions. I see too many people airing down their tires to ridiculously low pressures for hard ground, simply because they think they need ultra-low pressures anytime they are off-road. These are the people who deal with the lion's share of sidewall cuts.
Few people know that most sidewall damage can be temporarily repaired to get back to civilization, and it can usually be done without dismounting the tire. Still, I suspect I will travel many rough, rocky trails without ever cutting a sidewall on the OEM All Terain tires that will be coming on my Cybertruck because I know how to set appropriate tire pressures and how to pick good lines off-road. Always know where your tires are and what they are doing. It's not rocket science. People just become lax because sidewall cuts are infrequent unless you are really asking for it.
The low rolling resistance nature of the OEM All-Terrain tires will reduce traction off-road, it will not increase vulnerability to sidewall cuts. That's because low rolling resistance is achieved by stiffening the sidewall, using harder rubber compounds and shallower tread depths.
